Retrofit ABS
Beary
Beary
Besides this Im thinking less than $1k if you do it yourself based only on initial research. $1k would be worth it to me because I just bought the bike.
BRAKE LINE ABS module to caliper | ALL40610-09
BRAKE LINE ABS module to caliper | ALLat $54.33$54.33
Remove Item
BRAKE LINE ABS module to master cylinder | ALL40611-09
BRAKE LINE ABS module to master cylinder | ALLat $77.14$77.14
Remove Item
CONTROLLER electronic, ABS unit w/ 11904 | ALL40649-08
CONTROLLER electronic, ABS unit w/ 11904 | ALLat $477.43$477.43
Remove Item
MODULATOR ASSEMBLY hydraulic, ABS unit | ALL48343-09
MODULATOR ASSEMBLY hydraulic, ABS unit | ALLat $369.39$369.39
Remove Item
BRAKE LINE front, lower, ABS | FBM/FCM/FFM/FRM/KBM/KEM40612-09
BRAKE LINE front, lower, ABS | FBM/FCM/FFM/FRM/KBM/KEMat $111.60$111.60
Remove Item
BRAKE LINE front, upper, ABS | ALL41679-09
BRAKE LINE front, upper, ABS | ALLat $82.32$82.32
Remove Item
SENSOR wheel speed, ABS, w/ 10147, 72607-08, 72608-08, 72610-08 & 72639-10 | ALL40614-08
SENSOR wheel speed, ABS, w/ 10147, 72607-08, 72608-08, 72610-08 & 72639-10 | ALLat $92.26$92.26
Remove Item
SPACER (ABS, right only) | ALL41901-08
SPACER (ABS, right only) | ALLat $10.57$10.57
Remove Item
SENSOR wheel speed, ABS, w/ 10147, 72607-08, 72608-08, 72610-08 & 72639-10 | ALL40615-08
Remove Item
https://www.hdforums.com/forum/touri...l#post14099426
