I get it to a certain degree. I'm not trying to argue with you, certainly your bike. We have also had cars without air bags, abs, seatbelts, etc, all expensive stuff, but at the same time, deaths per mile driven have been reduced dramatically since we've had these innovations.
I speculate the percentage of people who think they can threshold brake in bad conditions under emergency circumstances without ABS is about 35-40%.
In reality, its probably .01 percent.
You're a biker, and I worry about bikers, what can I say? Ride safe, brother!
Thought you weren't gonna start a holy war here? The OP didn't say he could brake better without it, he doesn't want the expense of the parts required to work around the ABS. He also stated his light is on all the time anyway, so it probably needs serviced and is inoperable. His bike, his choice. Maybe he's a less is more kinda guy.
Funny how everyone jumps a guys chit for wanting to remove his ABS, and on the other side of the coin everyone is jumping another guys chit for wanting to add it. Can't we all get along. Give them the resources to make a decision for themselves, and what they do with that knowledge is their business.
I'm not giving anyone chit, I'm just worrying - like I said, I'm a worrier!
I was coming off the interstate on to a long straight off ramp about 70mph.
There is a red light and a sweeping left that went back under the interstate.
I could see in both directions, it was clear and nobody in front of me. Or so I thought.
As I'm slowing in high gear the light turned yellow, but it was clear and safe to go on through the light and nobody would know the difference. Or so I thought.
The light will clearly be red before I make it through as I'm only 30' from the intersection there's a state trooper setting in the grass on the other side in clear view of the light and I'm still 40mph.
There is no doubts the ABS works, I stopped right on the line and the trooper pulled out with a little wave and a smile. The abs stops, the technology came from racing, safer is the byproduct.
no like i said man i get it and i do appreciate it, i've just made up my mind you know what i'm sayin. Ride safe!
OP, how about spending an evening or two researching ABS before you remove it? At least be up on its benefits and be sure the concerns you stated outweigh what you uncover about its safety enhancements. You might well end up deciding to take it off. But if you go into it with an open mind…you mind change your mind.
