Exhaust header heat
Old Jun 12, 2015 | 12:36 PM
2013_FLHTK's Avatar
2013_FLHTK
Heat wrap may work. I've only done on a few softails and it worked great.
Old Jun 12, 2015 | 12:54 PM
Shark.Glide's Avatar
Shark.Glide
I've thought about heat wrap on the pipe only in the section that likes to fry my inner left thigh.
I know trapping heat where it stays in the pipe longer tends to lessen the longevity of the pipe, but a 1' section of pipe heat wrapped might be okay.
Old Jun 12, 2015 | 01:01 PM
lionsm13's Avatar
lionsm13
Originally Posted by 0ldhippie
Well you picked those pipes with the left exhaust against your leg. What did ya think would happen?
Left pipe is not against leg, and it is the other left leg....
right side clyde
Old Jun 12, 2015 | 02:20 PM
Captain Itch's Avatar
Captain Itch
Sponsor
Our product will do the job for you. Very easy to install and it has a little larger foot print than the others. But it will help you out .
__________________
www.Captain-Itch.com
Old Jun 12, 2015 | 04:37 PM
Delta's Avatar
Delta
+1 on the Crotch Cooler. I put one on a month ago and can't believe the difference it made. So much better then the stock mid frame heat shields.
Old Jun 12, 2015 | 05:39 PM
Shark.Glide
Will your shield hang down low enough to cover the rear cylinder head pipe where it comes out from under the frame/seat area and makes the sharp bend before it angles down to go under the saddle bag?
Old Jun 12, 2015 | 07:11 PM
0ldhippie's Avatar
0ldhippie
right side clyde
RIGHT TURN CLYDE - YouTube
Sorry! Maybe ya ought to know what you talking about before hitting the Keys???
"Rinehart True Dual exhaust system.
my left leg is practically touching the left pipe off the rear cylinder as it comes around from underneath the seat."
Old Jun 12, 2015 | 08:18 PM
timbo141's Avatar
timbo141
Old Jun 12, 2015 | 09:01 PM
lionsm13's Avatar
lionsm13
WTF are you blithering about?
You been self medicating too much on the green?
I SAID MY "RIGHT CALVE" not my left!!!
Check the thread!!!!
Not only that, but had maybe you been just a tad more observant (oh that's right you look through your windshield) you would have noticed in "MY SIG" that I run "Slimline duals" not Tru-Duals".
They are more like the 09 Head pipe.
Remember that expert?
AGAIN, MY RIGHT LEG, OK
~comprende~?
Dang....
Old Jun 12, 2015 | 09:19 PM
0ldhippie's Avatar
0ldhippie
~comprende~?
Dang....
Oh I get it, you think I was talking about your problem? This is the OP's thread, not yours. You get all up in a wad because I was staying on topic (as I quoted in my reply) with the OP rather then it being all about you. Wow thanks for all the personal attacks too. I'm not and never was addressing your left or right leg and sorry but now I don't really care if it burns off.
