Exhaust header heat
Old Jun 11, 2015 | 06:53 PM
Shark.Glide's Avatar
Shark.Glide
Default Exhaust header heat
I have a '07 Ultra Classic with 107" kit, Fueling Reaper 574 cams, SE adjustable pushrods, PC5, Stage 1 AC, and Rinehart True Dual exhaust system.
I'm only 5' 6" tall and when I have to stop at a stop light when it's hot outside, my left leg is practically touching the left pipe off the rear cylinder as it comes around from underneath the seat. I can flat foot my feet on the ground with my 1" shortened rear shocks.
I do have the plastic heat shields installed that mount on the sides of the frame under the seat.
Is there something I can do to reduce the amount of heat?
Ceramic coating, header wrap only on the area that touches my leg, or a different set of header pipes to run with my Rinehart mufflers?
Old Jun 11, 2015 | 07:11 PM
decencyxdefied's Avatar
decencyxdefied
Lower the bike so u can move ur legs further out
Old Jun 11, 2015 | 07:48 PM
mikelikesbikes's Avatar
mikelikesbikes
Captain Itch Crotch Cooler. Problem solved. Have one on my Road King and had one on my Road Glide. Forum sponsor and good people.
Old Jun 11, 2015 | 11:16 PM
Shark.Glide
I already have custom 1" lowered rear OEM shocks. I haven't lowered the front yet though.
Old Jun 12, 2015 | 06:18 AM
Olde Skool's Avatar
Olde Skool
RJS Originals. These are the bomb. Look great and work as advertised. Been to his house a couple of times. Great guy. He will talk you through the install if you get stuck. Simple to install if you follow the directions.
Get 'em here: http://www.rjsoriginals.com/
Tell him "Duck Butter" sent you, he will laugh...
Old Jun 12, 2015 | 06:25 AM
Noble Jim's Avatar
Noble Jim
Or, you could use Ward's Fans or Luv Jugs Fans to keep it from getting that hot in the first place.
Old Jun 12, 2015 | 08:20 AM
doorsidedown's Avatar
doorsidedown
I put the rush ceramic coated headers on my 08 king with the rinehart mufflers and the heat reduction is drastic. I couldn't emphasize this more. +1 on the fans too. I don't have them, but my buddy does and loves em.
Old Jun 12, 2015 | 08:56 AM
lionsm13's Avatar
lionsm13
I have the CC & have RJ's shields and have the Oil Bud Oil Cooler and have also been dyno-tuned and guess what my right calve still fries.
Jason that is the owner/manufacturer of Wards Fans said his fans might not address my issue or another member's.
So what is the solution?
Old Jun 12, 2015 | 10:14 AM
0ldhippie's Avatar
0ldhippie
Well you picked those pipes with the left exhaust against your leg. What did ya think would happen?
Old Jun 12, 2015 | 11:13 AM
Shark.Glide
It's pretty hard to know if a pipe will hit your inner thigh when you sit still at a stop light, without buying the pipes first and installing them....DUH! Your statement is rather stupid.
