Digital gear indicator
Old Jun 12, 2015 | 03:18 AM
Witney wanderer's Avatar
Witney wanderer
3rd Gear
Default Digital gear indicator
Hi
I have a Digital gear indicator HD part No: 70900078 fitted to my 09 Road King Classic. It has been working fine for the past two years, but now it will only display first gear and 8N in all other gears. Any thoughts as to the cause ?
Old Jun 12, 2015 | 06:44 AM
3/4 life crisis's Avatar
3/4 life crisis
Originally Posted by Witney wanderer
Hi
I have the exact same issue. Tried unplugging it and plugging it back in with bike both running and off. No go.
Remember reading somewhere this part won't work with OEM tourpak amp, which I have, but it did work for several weeks before it quitted.
Old Jun 13, 2015 | 03:37 AM
Witney wanderer
3rd Gear
Hi
I have since posting seen on another site, the issue maybe the Clutch Switch. I have had a look at my Clutch Switch and it seems it is damaged although it is doing its job. On Monday, 15 June, I am changing the Clutch Switch and I am hoping this will solve my problem. I will post again once the job has been done.
Old Jun 14, 2015 | 07:27 AM
3/4 life crisis
Hi
Please keep me posted. Thank you very much.
Old Jun 15, 2015 | 10:45 AM
Witney wanderer
3rd Gear
I have had my clutch switch changed, it has not made any difference although the switch was damaged. Back to the drawing board!!
Old Jun 26, 2015 | 07:58 PM
3/4 life crisis
OK, here is the weird thing. My kick stand spring broke, so I bungee cord it so at least I can ride the bike. Several times when I use the heel shifter, my heel touches the kick stand extension and felt different when I upshift. And since then, my digital gear indicator start working again, going on 4th days now.
I understand the indicator is electrical, but the shifter is mechanical, no idea why it started working again, I haven't touch the connector under the left side cover since it quit working.
Old Jun 29, 2015 | 03:21 AM
Witney wanderer
3rd Gear
Very interesting. As you know if the side stand is extended and the bike is in gear the bike will switch off, I wonder if the micro switch on the side stand could be my problem ?
TriGeezer
Milwaukee Eight (M8)
101
Jul 30, 2021 11:47 AM
mitman76
May 12, 2019 04:48 AM
Back-n-Black
Sep 8, 2017 10:41 PM
06SGWA
2014-2024 Touring Models
28
Sep 25, 2014 09:34 AM
hanny
11
Mar 12, 2014 07:56 PM
