Baisley oil pressure spring
Old Jun 16, 2015 | 04:51 PM
sanman4ever's Avatar
sanman4ever
Originally Posted by Softy 103
Axtell for me and it runs just under 50psi hot at speed.
Do you run an oil cooler?
Old Jun 16, 2015 | 07:25 PM
senna's Avatar
senna
Originally Posted by sanman4ever
At cold idle it's around 55-60 PSI. Once the motor reaches operating temperature hot idle is in the low 20's.
And 44-46 PSI hot cruising. The warmer the ambient temperature is will also effect the PSI as well. The hotter the oil gets the PSI will go lower.
I don't see those numbers with the Baisley spring. Of course I'm reading the factory oil pressure gauge.
I run low 40's hot at speed and 15ish at idle hot. I'd have to go fire it up to recall the cold idle psi, but it's not over 20psi.
I wonder if your Digital gauge is off, or maybe the factory gauges are off and our bike really aren't that bad off to begin with, LOL.
Old Jun 16, 2015 | 07:36 PM
sanman4ever
Default Baisley oil pressure spring
Troy are you running an oil cooler?
Old Jun 16, 2015 | 07:38 PM
senna's Avatar
senna
Yes, Jagg 10 row, no fan.
Old Jun 16, 2015 | 07:42 PM
senna's Avatar
senna
But you know what I did different?
I modified the filter adapter. I opened those 1/8" pipe fittings to a 3/8 pipe, which is the proper size for -6 fittings.
I felt those 1/8" fittings were to restrictive. Just a thought.
Old Jun 16, 2015 | 07:45 PM
sanman4ever
Maybe that hot Cali weather is driving your pressure down...
Here's my last stat on the matter:
Bailsy spring = $12.95
Axtell Bypass System = $84.99
Old Jun 16, 2015 | 08:03 PM
senna's Avatar
senna
Cali in general drives my blood pressure up!
Old Jun 17, 2015 | 06:48 AM
Softy 103's Avatar
Softy 103
It's a 12 FLHX, so yes it has the factory oil cooler.
cajun1957a
Aug 20, 2018 09:56 AM
Charlie Bone
EVO
39
Jan 29, 2016 03:58 PM
supercub12
General Topics/Tech Tips
Jun 14, 2015 06:50 PM
icebite1
57
Nov 1, 2010 04:59 AM
RBWIDE
Oct 30, 2008 07:44 AM
