Baisley oil pressure spring
Old Jun 14, 2015 | 06:54 PM
supercub12's Avatar
supercub12
Default Baisley oil pressure spring
Hey guys is there anywhere in Canada I can buy this spring....Thanks
Old Jun 14, 2015 | 07:30 PM
sanman4ever's Avatar
sanman4ever
I bought my straight from Zippers.
http://www.zippersperformance.com/
Old Jun 14, 2015 | 09:00 PM
senna's Avatar
senna
How are you liking the oil pressure compared to the Axtel set up?
Old Jun 15, 2015 | 07:35 AM
sanman4ever
Much, much better, I'm running the LMR-2 spring.
Oil is 44-46 PSI hot cruising, with the Axtell set up it was over 60+ PSI hot cruising.
Cold start with the Baisley is 60 PSI, once the motor reaches operating temps it's in the 44-46 PSI range mentioned above.
Old Jun 15, 2015 | 09:06 AM
senna's Avatar
senna
Good News.....
Old Jun 16, 2015 | 12:20 PM
B18cx's Avatar
B18cx
Same results here, just with the Axtell set up.
Old Jun 16, 2015 | 01:30 PM
sanman4ever
You're in the minority there I think. Seems like most run minimum 50+ PSI hot cruising with the Axtell set up.
I have a Jagg 10 row w/ a 140 degree thermostat as well as Wards fans and mine was 60+ PSI according to my DD gauges. Just not comfortable with anything over 50+ PSI.
Old Jun 16, 2015 | 01:33 PM
Otter's Avatar
Otter
What are you all seeing with the Baisley for hot and cold idle?
Old Jun 16, 2015 | 01:43 PM
sanman4ever
At cold idle it's around 55-60 PSI. Once the motor reaches operating temperature hot idle is in the low 20's.
And 44-46 PSI hot cruising. The warmer the ambient temperature is will also effect the PSI as well. The hotter the oil gets the PSI will go lower.
Old Jun 16, 2015 | 04:20 PM
Softy 103's Avatar
Softy 103
Axtell for me and it runs just under 50psi hot at speed.
