2009 Roadking odometer question
Old Jun 24, 2015 | 08:11 AM
128auto's Avatar
128auto
Question 2009 Roadking odometer question
I am adding a 09 RKC to my collection. I want to install a HD Speedo/tach and I want to know if the odometer reading remains the same. I have a Dakata digital on my Dyna, have to program the odometer before use. Do you guys have the part number for the HD speedometer? Thanks Alex
Old Jun 24, 2015 | 08:48 AM
Keithhu's Avatar
Keithhu
You mean this: http://www.harley-davidson.com/store...caps-_-PDP+Top
The install procedure for the speedo/tach combination takes you through reading the miles off the ECM.
Installation instructions: http://www.harley-davidson.com/app-c...ts/-J05306.PDF
Old Jun 24, 2015 | 08:56 AM
128auto's Avatar
128auto
So the odometer record is locked to ecm, am I correct? The reason I asked, I have been running a Dakota Digital on my 07 Dyna for a while, when I plug my factory speedometer, it still read the same mileage when I removed it.
Old Jun 24, 2015 | 09:26 AM
Keithhu's Avatar
Keithhu
I'm not sure if the mileage is locked to the ecm per se, but the speedo/tach combo reads off the ecm, then it locks/marries to your bike, so at that point you're good to go.
Old Jun 24, 2015 | 11:11 AM
128auto's Avatar
128auto
Thanks!
Old Jun 24, 2015 | 11:36 AM
FlaHeatWave's Avatar
FlaHeatWave
Used to be that you had to get the mileage documented by a Dealer, then the Dealer would send info to HD, HD would send a speedometer with the documented mileage back to Dealer for install.
I don't know what year HD started having the ECM record the mileage? (sometime in the mid 200-s I think?)
SnoRider
Touring Parts
Jan 20, 2018 11:53 AM
apblingAEW
Jul 18, 2015 12:39 PM
alcotune
Feb 6, 2015 03:58 PM
Crazylegs
Oct 18, 2012 01:17 PM
albatross
Mar 31, 2010 02:44 AM
