Shifter link broke!
Old Apr 29, 2007 | 03:43 PM
bay13's Avatar
bay13
Default RE: Shifter link broke!
The arrow points to the area where the ball is, it's beneath the rubber boot. The boot doesn't keep out all the road grime and in time that wears on the plastic seat that the ball snaps into. Replace with Kuryakyn they have a much better set up for the ball and socket. (plus it's chrome)
Old Apr 29, 2007 | 06:54 PM
03RKC's Avatar
03RKC
E-Z Brake sells quality shifter and linkage. Love the extended brake petal also.
Old Apr 30, 2007 | 12:09 AM
curmudgeon's Avatar
curmudgeon
Genuine Harley Davidson duct tape. $12.95 for a 36" roll part number 98-987554-02
caution improper use may cause serious injury or death
Old Apr 30, 2007 | 12:23 AM
wesd41's Avatar
wesd41
Thanks, bay13.
Old Apr 30, 2007 | 09:16 AM
HogBack's Avatar
HogBack
Zip ties are the modern hay baling wire.....
Hogback
Old Apr 30, 2007 | 09:48 AM
RanD's Avatar
RanD
I never had mine break there, but on my '03 RK I had the rod that connects the toe/heel shifter to the other side where the linkage is become stripped, and as a result I could only shift by reaching down and doing it by hand. Due to the fact that the clutch and shifter are on the same side, I was unable to change gears while under way. Luckliy this happened about 10 miles from an H-D dealer. I used third gear for the whole way there. Getting started from a dead stop in third is a bit of an experience[&:].
Old Apr 30, 2007 | 11:48 AM
mkultra's Avatar
mkultra
Yep my 03 Roadking went thru a couple of em befor i got one with a Heim joint...both times in the mountains, and both times i used wire from along the road to fix it.
Old Apr 30, 2007 | 01:31 PM
iclick's Avatar
iclick
Had this happen on my old RK with about 100k miles at the time. I carry a good complement of tools, but didn't carry wire ties at that time. Fortunately, my riding buddy had some, and I limped home with no further problems. I also met up with a nail in my rear tire on the same trip, which I fixed with a patch kit and small 12v pump, so it was an overall bad day.
The heim jointed end, if there is one, is not the problem. It's the ball-and-socket part on the stock rod. On my new bike I'm putting a drop of oil under the rubber cover about every oil change, which I never did before. These B&S joints just wear out over time, and oil should extend the service life. The best idea for a fix is to buy one of the aftermarket HD shifter rods that are heim-jointed on both ends. I think these will last much longer. I wish you could buy just these joints for the stock rod. I may buy one of the fancy rods just to get the heim joints.
Old Apr 30, 2007 | 04:20 PM
alexcue's Avatar
alexcue
dunce question of the day: How easy is it to replace this part? Can a guy whose all thumbs do it pretty easily?
Just ordered the scipted "ultra" one, to avoid this problem in the future. Even my service rep said it was a good idea.
Old Apr 30, 2007 | 04:30 PM
sleepneagle's Avatar
sleepneagle
yup, it happens. two zips and your back in business.
