Setting the timing on 2006 Road King
Old Apr 30, 2007 | 02:43 AM
voodoodrug's Avatar
voodoodrug
Default RE: Setting the timing on 2006 Road King
that il work. dont know if air manifold will need replace too? can get pricey. Id just try to get the mikuni runin with the jet thing that others have suggested.
Old Apr 30, 2007 | 03:22 AM
hogdoc's Avatar
hogdoc
If it is Mikuni flat slide carb dont even think about replaceing it with an S&S. The Mikuni will always run better when you get it dialed in. What pipes, Baffles? if ther are slip on pull them off and use Permatex Ultra Copper inside the muffler and make sure the clamo is all the way to the front of the muffler where it is split. cant clamp solid pipe. If it is a timing issue for the motor combo you have there is a Screamin Eagle Adjustable Map Ignition module that you can set rev limit and advance.
NEIMIS67
Aug 6, 2018 05:16 PM
Bagged64
Motorcycles For Sale
Mar 27, 2015 11:44 PM
ggrif
Jun 6, 2011 09:19 PM
lumbee2006
Nov 8, 2007 08:56 PM
rbrapp1
May 6, 2007 01:23 AM
