One More Stupid Question
Old Jul 8, 2015 | 08:57 PM
Bachus's Avatar
Bachus
Default One More Stupid Question
09FLHTP
Came home from work last Sat., yes, Forth of July, Low fuel light comes on 5 miles from home. Got a 10 mile ride back in in the morning. All I have @ the farm is crappy 87o gasohol and a couple of gallons of VP C105 race gas.
Poured about 1/2 gallon of the VP in the bike for extra reserve. Left home @ 5:30Am w/34 miles to empty. Bike SMELLED wonderfull when I pulled into work, you all know the smell of RACEGAS! Bike was reading 47 miles to empty when I got there. Ran down and filled her up with 91o after work.
My question is,
C105 is 105 octane, oxygenated, LEADED fuel. IF leaded fuel would cause problems with fuel injectors? Lead should lube up the valves, not running stock O2 sensors, PCV, sensors disconnected, as I know leaded fuel can play havoc on O2 sensors. Just wondering if leaded fuel would cause harm to injector system.
Thanks.
Dan B.
Central Ks.
Old Jul 8, 2015 | 10:00 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
catalytic converters are the big things, the lead shouldn't hurt anything if you don't have them
I have never heard of lead fouling an injector
sometimes I get lucky and come across some 100LL at the airport.
sweet smell, and that white residue in the pipes.
Old Jul 9, 2015 | 07:57 PM
LA VIC's Avatar
LA VIC
Originally Posted by Bachus
09FLHTP
My question is,
Thanks.
Dan B.
Central Ks.
Just remember any octane fuel number higher than the minimum required to keep your bike from detonating is just a waste. Octane doesn't mean power just the resistance of the unburned mixture in the combustion chamber to self ignite after the plug fires. That's the ping you hear. It's after the plug has fired not when the plug fires.
ScreamingRK
Aug 24, 2019 10:14 AM
John L. Goldsmith
Exhaust System Topics
Aug 17, 2019 08:37 AM
spiczchef
Jan 26, 2009 06:11 PM
MDodson
Jul 4, 2008 09:47 AM
dert
Aug 22, 2005 11:25 PM
