Handlebar Fitment Question
Old Jul 21, 2015 | 11:28 AM
Ridewva's Avatar
Ridewva
Default Handlebar Fitment Question
I've never changed bars before and I'm searching handlebars to replace the stock ones on my RK with ones about 2" lower. I would like to get as close as possible to the rise and pull back that were on my 09 FLHT which fit me to perfection. Unfortunately those exact bars have a wide base to rise almost vertically through the batwing and their knurl width is slightly wider. Is exact knurl width critical or can 3.14 and 3.50 be interchanged?
I've sat on 08-13 RK's which have different bars but their 7" rise feels almost too low for me.
Stock 15-15 RK bars:
Bar diameter 1
Width 31.25
Pull back 5
Rise 12
Base width 11.50
Knurl width 3.14
FLHT bars:
Bar diameter 1
Width 30.25
Pull back 6.25
Rise 9.75
Base width 15.75
Knurl width 3.50
I found 56563-95 which are sized pretty close to my ideal but are listed as fitting Sportsters and some Dyna's. Just curious what if anything is it about bars such as this, that they fit Dyna's but not Tourers? (RK's don't have internal wiring or cables.)
56563-95
Bar diameter 1
Width 31.50
Pull back 5.50
Rise 9.75
Base width 9.50
Knurl width 3.14
Old Jul 21, 2015 | 01:50 PM
jimmything's Avatar
jimmything
Don't know if you've checked out http://www.wild1inc.com/, but the site is very helpful with specs and pics.
Old Jul 21, 2015 | 02:11 PM
Ridewva's Avatar
Ridewva
Thanks Jimmy yes I have, along with the handlebar chart in the HD catalog and sitting on various bikes at the dealership. It's probably gonna be a PIA changing them with TBW and heated grips so I want to be sure and just do it once!
Old Jul 21, 2015 | 02:51 PM
jimmything's Avatar
jimmything
I've done it twice. Yea, a pita, but it's worth it. Take your time, and do it right. I put 9" extentions for my controls. I soldered them, and put heat shrink over them, including the tiny TBW connector, which I broke the tiny clip that kept it from seperating, so I put some heat shrink over it too and never had one problem for about 5 years so far. I never needed longer brake or clutch cables with my bars either.
Old Jul 21, 2015 | 03:38 PM
Ridewva's Avatar
Ridewva
Yeah fortunately going a couple inches lower should't require changing the throttle wire. I'm sure I'll have to change the brake line and clutch cable. Not sure how to remove the left heated grip w/o damaging it though?
Old Jul 22, 2015 | 09:32 PM
pjones1969's Avatar
pjones1969
I put these on my FLHX, used the factory cables but had to reroute the clutch because of the angle where it came out of the inner fairing, I believe some of the pics show them on a RK, 7" wider, 2-1/2" lower and 1/2" more pullback as stock FLHX bars, doesn't say anything about heated grip comparability, I don't have those.
http://www.lachoppers.com/catalog/di...059/index.html
According to this chart the FLHR and FLHX have the same stock bar dimensions
http://www.sideroadcycles.com/Import...ckBarsOne.html
Old Jul 23, 2015 | 06:21 AM
Ridewva's Avatar
Ridewva
Thanks the chart in your link is helpful. I'm not sure I want handlebars 38" wide though?
Just stumbled on to this thread, perfect! https://www.hdforums.com/forum/touri...andlebars.html
Old Jul 23, 2015 | 08:39 AM
NDBadlands4-2's Avatar
NDBadlands4-2
Look into Helibars They are adjustable in various angles, height and width. I put them on my Limited and absolutely love them.
Old Jul 23, 2015 | 10:24 AM
crimson13's Avatar
crimson13
I don't have a suggestion other than agreeing with what pjones posted.
I was skeptical of wide bars also at first , after riding with them I find the wide bars being a lot more comfortable than narrow. To me the wide bars put me I am more natural seating position.
I have 14" apes on my limited now , but more than likely will be swapping to the big Johnson bars on the future.
Old Jul 23, 2015 | 09:08 PM
pjones1969's Avatar
pjones1969
You'd like them!! seriously though, I hear you, I looked forever before deciding on the Big Johnson's, it's a personal choice for sure and like you I only wanted to do it once, good luck and keep us posted on what you decide
Chunker
2018+ Softail Models
Jul 25, 2019 07:02 AM
Rnt77
Jun 10, 2013 02:43 PM
mashbolt
Nov 28, 2010 09:22 PM
Mike Horrell
Sep 10, 2009 01:54 PM
HDChloe
Apr 8, 2007 11:39 AM
