Belt deflection question
Old Jul 25, 2015 | 05:16 PM
Litewings's Avatar
Litewings
Default Belt deflection question
I have adjusted the belt deflection on my 13 Street Glide before and done to Service manual specs, it just seem so damn tight! I set it to the larger of the manual specs, 5/16 if I remember correctly. Why is the Road Glide and the Street glide a 1/8" less in the manual than the other touring bikes? Would it be because of the shorter shocks on the SG, (don't know what the RG has)? I have Ohlins 3-3 shocks that are about 13 inches long like the other touring bikes, not the stock 12" length. Should I be using the other touring bike specs for belt deflection?
Old Jul 25, 2015 | 07:01 PM
sixguns's Avatar
sixguns
An educated guess would be yes, change to the spec for the other bikes with the longer shocks. I will add that the tension gets tighter as the bike warms up, I only adj when the bike has sat overnight and I use the max adj of 9/16 for my 2014 RoadKing.
Old Jul 26, 2015 | 06:58 AM
grbrown's Avatar
grbrown
Your longer shocks change the geometry of the swingarm, which affects the belt length/tension, so you are right to be concerned about it being too tight! I recommend you use the belt tension spec for the models with 13" shocks, not your 12" SG shocks.
Old Jul 26, 2015 | 08:30 AM
Roomer's Avatar
Roomer
I'm with grbrown. My tuner recommended this as well. Set deflection to maximum for electra glide on a streetglide. 9/16" I believe.
Old Jul 26, 2015 | 09:48 AM
Bikerscum's Avatar
Bikerscum
The Limited & Limited Low have different specs too, because of the shocks. I set mine on the loose side. Maybe looser than on the loose side. In spec is TIGHT.
I think maybe the MOCO is more worried about drivetrain smoothness than longevity. I'll take a little slop in there.
Old Jul 26, 2015 | 07:41 PM
mikeo33y's Avatar
mikeo33y
set mine today to 3/8. seems perfect. some will say an extra 1/8 is good. im happy with 3/8 to 1/2. i set in while on jiffy stand
Old Jul 26, 2015 | 07:57 PM
Litewings's Avatar
Litewings
Set it again today to the upper limit for the 13" shock bikes according to the service manual. 7/16 is much better. Didn't have time today but want to unbolt the shocks and play a bit with the rear suspension. Curious on belt tension as the swingarm moves up such as when your loaded two-up without adjusting shock preload or hit a large bump.
Old Jul 26, 2015 | 08:26 PM
mikeo33y's Avatar
mikeo33y
as the suspension compresses, the belt will tighten. this is why i set mine on the jiffy stand as the service manual suggests as an alternative to being on a lift. have a 13 ultra with standard length shocks. belt is perfect tension. no issues with 19k on it.
SWThomas
Milwaukee Eight (M8)
13
Apr 11, 2019 12:29 PM
kyle8095
Feb 28, 2016 04:50 PM
philo111
Jul 25, 2015 09:08 AM
Voelser
Jul 18, 2012 04:00 PM
mogle
Oct 29, 2008 06:14 PM
