Fairing For Road King
However, most guys with detach fairings wind up leaving the fairings on virtually all the time, taking it off likely won't be an issue.
The problem with the detach fairings is that they sit too high, and are tipped forward, compared to a stock fairing. They look good, but they look aftermarket. Most folks probably won't notice, but die hard Harley guys can spot an aftermarket fairing from across the parking lot. If you change to bagger handlebars, and work the brackets, you probably could get an aftermarket fairing close to the stock position.
The best solution is just do the street glide conversion. Some guys do the whole thing, including changing to the fairing model main wire harness, which allows the fairing interconnect to just plug in, along with the handlebar wiring, etc. That's what I did with my Road Glide conversion. Everything on my bike works as factory, including the radio, gauges and hand controls.
Some guys are spending upwards of 2K for a detach fairing loaded up with audio gear, and for that money, you can do a full fairing conversion (Street Glide or Road Glide).
If I wanted gauges, I am sure he would have cut the holes for me...good luck deciding.
Mike, glad you posted about the fairing sitting high. Maybe I will modify the bracket to sit it lower, but then again I'm 6'4 with a long torso so it shouldn't bother me. And I'll agree about them being expensive man. When the rep for Hoppe at Americade told me the fairing was $1800 not painted I almost fainted. From what I'm reading, the Reckless unit painted will run me $1200.
