2014 SG Speaker Boxes - Needed?
Old Jul 28, 2015 | 06:04 PM
mbuesing's Avatar
mbuesing
Default 2014 SG Speaker Boxes - Needed?
I'm having a hard time fitting a set of Rockford Fosgate speakers in the existing white, speaker boxes, in my fairing. The issue is the tweeter will contact the speaker grill. I don't have new grills, but I want to install the 6.5 in speakers and an amp, before I leave for Sturgis Friday.
Has anyone put the speaker inside of the speaker box? Issues? OR Can i just mount the speaker to the fairing and eliminate these boxes? What is their benefit? They are a pain to remove and I don't want to spend the time to tear them off, if I can't get things to fit. OR has anyone used a different grill?
Thoughts and thanks!
Old Jul 28, 2015 | 06:26 PM
HD_Doobie's Avatar
HD_Doobie
I had my Kappas inside the pods and they sounded good, then I tried them on the outside like the stock speakers are mounted and they sound MUCH better. You MUST have the enclosures installed! They are your fairing supports! I have the V Twin audio grills installed to clear the tweeters and they work great. I had to slightly modify them...just a clip here and there with the wire cutters but I like them alot.
Old Jul 28, 2015 | 06:27 PM
mbuesing's Avatar
mbuesing
Ok, sounds like extended grills are the way to go.
Old Mar 6, 2016 | 12:08 AM
highyella94's Avatar
highyella94
Stage I
mbuesing-
I just purchased these Rockford Fosgate speakers and have the same clearance issues with the HD speaker grills and tweeter cone on speaker. Can you provide any information on what you did to modify speaker pod or make your RF speakers fit? Any information would be helpful. Thanks!
SE120RG
Audio Systems
20
Nov 14, 2014 12:09 PM
0ldhippie
Dec 31, 2012 07:26 AM
CGLTD
Jan 17, 2010 05:08 PM
Grunt66
Sep 1, 2009 04:41 PM
cwilks
Aug 13, 2007 10:08 PM
