Charging volts 14.40?
Old Jul 29, 2015 | 08:11 AM
mgmmgm's Avatar
mgmmgm
Thanks all for the input, I will investigate my issue further.
Old Jul 29, 2015 | 01:03 PM
Blowby's Avatar
Blowby
Same problem here. 1 year old Westec 400ah battery. Went to auto parts store and they tested and said it was good but would show amber led after it sat over night. Replaced with a Mega Crank and with my luck I got a dud. It worked great for 30 days then led was red over night. Called Battery Mart and the said they have sold over a thousand without any problems. Exchanged for a new one and all is well for the last 9 days.
Old Jul 29, 2015 | 01:11 PM
bagman1's Avatar
bagman1
Mind if I asked why you didnt go with the Deka battery from battery mart? Been told here it was the same as oem for $80 less. I hope theyre good mie will be here on Tuesday
Old Jul 29, 2015 | 02:43 PM
Blowby's Avatar
Blowby
The Big Crank is the Deka and is 400cca / 26ah. I talked with the rep and he is very happy with the results of the Mega Crank (non Deka) 420cca / 30ah.
I just wanted a little more juice for playing the stereo and turning over my high compression motor.
Old Jul 30, 2015 | 03:58 PM
TomWoodgeard's Avatar
TomWoodgeard
There is a new battery by Dekka. Part # is WPX30L-LS 30ah and 600 cca
Really spins the motor over. The name for the battery is "Lightning Start"
Available at Amazon.com for $129.99, and free shipping. Just search WPX30L-LS
Old Jul 30, 2015 | 04:57 PM
btsom's Avatar
btsom
Rats, I just got a new 400 cca Deka, like the specs on the new battery. Just for grins I am doing a few calculations. 600 cca times 12.5 volts yields 7500 watts. 746 watts equals one horsepower yielding a THEORETICAL 10 horsepower from your starter. I am confident that there are losses that cut pretty deeply into that but it is still better than the factory battery. Beyond my ability to calculate is how many amps or watts our factory battery cables can carry before heat loss becomes significant. I suspect that 600 cca gets pretty close to their limit. Given my success with Deka batteries I almost look forward to needing my next battery so I can get the 600 cca unit.
Old Jul 30, 2015 | 05:00 PM
bagman1's Avatar
bagman1
I just went to battery mart site and the don't list anything other than the ETX big crank
Old Jul 30, 2015 | 05:50 PM
btsom's Avatar
btsom
While you were checking Battery Mart site I wrote them a note asking when or if they plan to carry the new Lightening Start Deka battery. It's only been 10 to 15 minutes but I don't really expect an answer until tomorrow at the earliest. I will post when the answer comes in.
Old Jul 31, 2015 | 10:11 AM
MilesOfTexas's Avatar
MilesOfTexas
Good or not, I always change my battery every four years.
Old Jul 31, 2015 | 01:52 PM
zoozoo's Avatar
zoozoo
Yep, 4 years is when I buy a new one. I just don't want to be stranded in the middle of no where. Not fun!
