Fluid Leak
Old Aug 11, 2015 | 09:19 AM
jcannady's Avatar
jcannady
Default Fluid Leak
Hey Guys,
Sorry for the moron question but I need help with a minor leak. I have a 2013 FLHR with stage 1. It has about 6k on it. No problems until Spring when I took out a small mailbox. Shop guys inspected it and I replaced the front fender, engine guard, and the left bag. I've ridden it a lot since but most have been short rides to work. No problems.
I noticed a small spot in the garage yesterday. First one. A few days ago I put a couple of hundred miles on it. The most since the mailbox. When I finished a 50 mile ride yesterday (it's Georgia BTW, and hot) I parked it and noticed a drop of fluid (oil?) on the bolt in the attached picture. There was also some oil+dirt mix on the bottom of the pan behind it. This is at the front end of the bike.
Can somebody tell me what I am seeing in the picture? What is that bolt? What sort of fluid could it be?
Any advice is appreciated.
Jim
Old Aug 11, 2015 | 11:59 AM
14GuineaPig's Avatar
14GuineaPig
Did you have the oil & filter change recently. I think the bolt that is shown is a front motor mount bolt. If the oil filter was changed recently, oil may have dropped on the mount when the old filter was removed. If no oil change then I would look closely at the oil cooler and the hoses connected to it for possible damage from the mailbox adventure.
Old Aug 11, 2015 | 12:08 PM
jcannady's Avatar
jcannady
No oil change in over a year. I'll get the cooler checked.
Thanks,
Jim
Old Aug 11, 2015 | 12:15 PM
FX4's Avatar
FX4
Feel around the stator wire outlet from the primary and see if there is any oil there.
Old Aug 16, 2015 | 07:57 AM
cmass's Avatar
cmass
Do you have any more pictures so we can see more areas where the oil is? I'd recommend first taking a good degreaser (AMSOIL makes one), spray the area good, let it sit for a few minutes, rinse with low pressure water, blow dry off. After running it, you might be able to get a better idea seeing fresh oil from the leak to give you a better idea where it's coming from.
bassman64
Oil Archive (no new posts)
Sep 10, 2018 09:17 AM
3rdEyeStreetGlider
Jul 27, 2017 01:16 PM
RidemyEVO
EVO
May 15, 2015 03:59 PM
1/2crazedbikr
EVO
Jan 9, 2013 03:50 PM
ChopinRockwooD
Apr 20, 2009 02:42 PM
