speaker system upgrade.
Old Aug 16, 2015 | 06:06 AM
just plain john's Avatar
just plain john
Most aftermarket amps are 2 or 4 ohm stable, meaning almost any speaker will work with them. Do not be concerned with your head unit's impedance, it's the amp that drives the speakers. No worries with your stock speaker wires either, you'll need to run your own. With a stock head unit, you'll need to use the existing speaker wires for the input into the amp. Most aftermarket head units have RCA connectors, as do the amps mentioned above. Your new amp will come with a small harness for the input. Get some velcro, attach the amp to the head unit, existing speaker wires to the amp, new speaker wires to your upgraded speakers. Easy peasy.
Old Aug 16, 2015 | 06:44 AM
MikeTD3's Avatar
MikeTD3
2 years ago I picked up a used HogTunes amp ($50) and new Polk 651 6" speakers ($80) I no one can tell me it was not "worth" it.......they sound much louder and clearer than stock by a pretty good measure.
Stereo upgrade advice is like asking what cam works best, or which oil should I use; you get an infinite amount of "opinions"...none of which are necessarily more right than the other.
Old Aug 16, 2015 | 06:57 AM
just plain john
OP, you do realize that there's an audio section in the forum, correct? You're likely to get more responses from people that have quite a bit of knowledge collectively.
Old Aug 16, 2015 | 07:27 AM
zwildman's Avatar
zwildman
Originally Posted by Roadglide Mike
Ok my apologies. Plug in play meaning. I dont want to hack up the stock harness to wire the speakers (is there such a amp kit. I dont mind running the power, ground, and remote wires. I notice the H&K headunits have a nice T harness for the audio wires thats kind of what I was hoping for.
As for fm id like to still have great radio reception.
Hawg Wired makes one that uses the stock wires and connectors. It's literally plug and play, works with the AVC and sounds good. But, it's not terribly loud at highways speeds; it's very clear and you can hear the music well but it's not in your face. With the AVC on cranking it past about 3/4 volume does not increase volume, the amp may be power limited to prevent damage to the speakers, I'm not sure why exactly. Good system and worth the price, IMHO. Link to the system below.
http://hawg-wired.com/product_info.p...h/49/pPath/146
Old Aug 16, 2015 | 09:19 AM
Softy 103's Avatar
Softy 103
Originally Posted by haze324
That fosgate package is not worth it. That amp only pumps out about 40-50w per channel.
Look nothing is going to be "plug and play". Any amp that is worth a damn will require you to run power and ground back to the battery. If you can do that, you can install anything you want.
Not sure why someone thinks the pre-14 fairing is any worse than the rushmore pods? Those things are even worse for bass. But yes, you're not going to get tons of bass from any 6.5 at volume since after all a 6.5 is mid range driver.
How many speakers are you trying to upgrade? Just fairing. If you're trying to do anymore than that you'll need more than 300.00 for it to be worth it. The one major thing to consider is that the majority of the amps that we can use on our bikes are class D amps, and those amps will cause some, none, or all loss of FM reception. It's really a roll of the dice. The only amps known not to cause any loss is the Fosgate PBR300 and the Biketronics amps. The first one isn't that great. The second one is great but cost well more than your budget.
So if you are ok with rolling the dice and just upgrading your fairing speakers, I'd get the Cerwin B2 Amp - 115., the Infinity Kappa's 115.00, adaptors 25.00, amp wiring kit, 15.00, roll of poly fill 10.00 and you'll notice a HUGE difference. Much better than any plug and play system.
Wow you say the Rockford amp isn't that great and not worth it, I beg to differ, I have that set up with the Kappa's and I think it is awesome, nearly every one that listens to it always asks what do you have for a set up? I want one of those
Old Aug 16, 2015 | 09:42 AM
Simonizer's Avatar
Simonizer
I have a RF punch 300 amp with Titan 7.1's, original head unit, I like this set up very much, I blew threw a Polk set of speakers previous, all good now. Good luck, well worth the upgrade.
Old Aug 16, 2015 | 09:55 AM
haze324's Avatar
haze324
Brother I've had just about every amp that you can have that fits in a fairing in my bike. Fosgat PBR, Fosgate T400X4ad, Arc Audio 600.4, Arc 125.4, Biketronics 4180, Power Acoustik, Soundstream, Clarion, I could keep going...and im telling you -- It's not that great. It's one of the few options that keeps FM and there's not many out there that 100% do. But sound quality wise there's much better options out there and in a similar price range the Cerwin is a much better amp. Beg to differ all you want.
Old Aug 16, 2015 | 10:52 AM
Softy 103's Avatar
Softy 103
Sounds like you have spent a lot of money on amps, I bought one and am very happy with it, I would say I got a lot more bang for my buck. Thats why there is chocolate and vanilla, every one likes something different.
Old Aug 16, 2015 | 11:06 AM
haze324's Avatar
haze324
Audio is my hobby, as it is for a few friends and we swap and trade equipment all the time. It's not about bang for my buck, didn't know we were in competition here? Trying out equipment is about MY enjoyment and then coming on forums such as this one and sharing that advice and experience with guys like the OP so they end up with the best system they can afford. Not the one someone thinks is great and has nothing to compare it to.
Has nothing to do with chocolate or vanilla, the PBR puts out 150w @ 2 ohm. The Cerwin puts out 250. The boosted rail technology is not as clean as the class D on the Cerwin and the added headroom allows for cleaner sound. Bottom line at 120.00 the Cerwin is a much sounding better amp than the 150.00 PBR.
Old Aug 16, 2015 | 11:29 AM
Softy 103's Avatar
Softy 103
