Bad ABS control module. Thinking about removing ABS system?????
Old Aug 16, 2015 | 01:33 PM
zoozoo's Avatar
zoozoo
Fix or replace and move on. It's not the last time you will be hit with an unexpected expense if you live long enough. It happens to all of us.
Old Aug 16, 2015 | 03:34 PM
smithbrl's Avatar
smithbrl
See if the dealer can turn off the ABS light or just deal with it being on all the time. Get new wheel spacers if you ever have to change bearings and go with non ABS bearings?
PS: You can't ask "Why not just go old school with the brakes?" and then say "no preaching". Preaching is generally how those kind of questions get answered around here.
Welcome to the forum.
Old Oct 10, 2015 | 02:53 PM
retiredjedi's Avatar
retiredjedi
Stage I
Originally Posted by flhxkiller
I was told pulling the fuse wouldn't fix the issue when my ABS module failed, mine had a nearly frozen front brake lever when it failed. Was told the new linked system ABS module is a $1200 part.
Make a report to NHTSA, Harley needs to recall these modules. Sometimes it's the front lever, sometimes the rear pedal. No warning when it will happen. Remember, dead bikers cannot file reports.
Old Oct 10, 2015 | 03:32 PM
btsom's Avatar
btsom
Pulling the ABS fuse will give you non-ABS (regular brakes) UNTIL that one killer malfunction happens, the frozen lever or pedal. For that possibility alone I refuse Harley ABS until it is redesigned. If your bike won't go, that's bad. If it won't STOP, that is a disaster!
Old Oct 10, 2015 | 04:55 PM
GTK's Avatar
GTK
Jeez,I thought the thread was dead.Now we have posts about recalls and potential injured riders.Where will it end?
Old Oct 10, 2015 | 08:20 PM
btsom's Avatar
btsom
If the ABS module hydraulic lock malfunction is new to you, you don't visit the forums often enough. There are several reports a year of the lever or pedal becoming rock hard and no pressure is sent to the caliper resulting in no brake. The pressure from the lever or pedal is stopped at the ABS module by a valve malfunction. It is serious enough to have ABS die and you unexpectedly skid a tire but brake loss is even more serious. It has been happening for several years. As of now there has been no recall but many believe there should be.
Old Oct 10, 2015 | 08:50 PM
GTK's Avatar
GTK
Well ,I see I am going to have to stay up on the forum members threads about all the problems they are having with the ABS system.Just don't know how I missed all those posts.I do know of several instances where owners have had the ABS malfunction warning light come on and instead of taking to a dealer,they continue to operate the vehicle or pull the ABS fuse and then they encounter a problem.That is called rider stupidity and not a basis for a recall.JMHO
Old Oct 10, 2015 | 08:54 PM
KumaRide's Avatar
KumaRide
Agreed, please report to NHTSA. This is a serious, life threatening problem. And not uncommon.
Pulling the ABS fuse will give you non-ABS (regular brakes) UNTIL that one killer malfunction happens, the frozen lever or pedal. ....
100% true.
Sure, no problem to you. Until this happens to you or some one you know.
Accurate again. This has also happened to vrods. As an abs rider, this is HD BS that needs to be recalled ASAP!!!
Old Oct 10, 2015 | 08:59 PM
JMC22's Avatar
JMC22
To each their own but if it were me, I'd anti-up to replace it - I'd try and buy the part thru Surdyke or someplace and then pay a local mechanic to install and bleed the brakes...I love my anti-lock brakes
Old Oct 10, 2015 | 09:18 PM
KumaRide's Avatar
KumaRide
Forgot to mention, I know a guy who cleaned inside the module valves with contact cleaner and air. Used mightyvac to bleed and it is working perfectly.
