torque spec
Old Aug 20, 2015 | 05:26 PM
jmn1960's Avatar
jmn1960
Default torque spec
2005 ultra
replaced the front motor mount , cant find in the manual the correct torque spec , I put it at 25 ft lbs , but getting some low end vibrations that was not there before ,, I know the 79b mount is now a 79d and it is a stiffer rubber material so mabe it will break in ,, just wondering if I have it tight enough.
thanks mike
Old Aug 20, 2015 | 05:59 PM
mkguitar's Avatar
mkguitar
06 manual specs 15~20 ft lbs
Bottom
l Front stabilizer link - on left side of motorcycle, tighten
eyelet bolt to frame weldment to 18-22 ft-lbs (24-30 Nm).
See D of Figure 1-26.
l Moving to right side of motorcycle, tighten eyelet bolt to
block on front engine mounting bracket to 18-22 ft-lbs
(24-30 Nm). See E of Figure 1-26.
l Verify tightness of jam nuts on front stabilizer link.
l Tighten center front engine mounting bracket to rubber
mount bolt to 15-20 ft-lbs (20-27 Nm). See F of Figure 1-
26.
l Tighten the two front engine mount to frame crossmember
bolts to 15-20 ft-lbs (20-27 Nm). See G of Figure 1-
26.
l Tighten two engine to front engine mounting bracket
bolts to 33-38 ft-lbs (45-52 Nm)
mike
Old Aug 20, 2015 | 06:14 PM
jmn1960's Avatar
jmn1960
Bottom
26.
26.
mike
thanks mike ,, I could not find that in my 2005 manual , I better look again in the 1- section ,,
thanks mike
Old Aug 20, 2015 | 09:04 PM
Stansuski's Avatar
Stansuski
Just removed my 79D mount after only 1 week, I hated the increased vibration, I replaced it with a Glide Pro , wow what a difference.
Stan
Old Aug 21, 2015 | 01:31 AM
skypilot_one's Avatar
skypilot_one
Stan
👍👍Glide Pro mount
cromagnon
Mar 28, 2017 10:16 AM
Cblast
Sep 15, 2010 11:38 PM
st john
Aug 12, 2008 10:53 AM
Pipedope
Jul 11, 2007 12:27 AM
Brackneyc
Jul 2, 2007 01:15 AM
