Anything else to stabilize handling?
Old Jan 19, 2016 | 02:41 PM
  #41
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Originally Posted by Lowcountry Joe
Digging up and old favorite:
https://youtu.be/Gmw6QppXnEY
Look very closely at those few instances where you can somewhat see the rear tire and fender as the bike goes into a wiggle. Notice the relationship doesn't seem to change as the bike wiggles. That rather strongly indicates that the rear wheel is not moving side to side under the bike.
Keep looking and you can sometimes sort of see that the bike appears to be swinging back and forth around the steering head, with the front and rear doing opposite things around the steering head.
Which isn't to say very much, as the entire video is of extremely poor quality. So it's darn hard to discern much, especially with any sort of certainty.
If you've experienced wobbling on your bike in a turn, you can try something out yourself. Dive into a turn, and gently wiggle the handlebars. Does this feel the same as the wobbling you experienced? I know it does on my bike.
I strongly suspect a whole lot of bagger wobble lives there in the undampened and extremely loose steering head.
Old Jan 19, 2016 | 07:30 PM
  #42
HFS's Avatar
HFS
Hmmm, I have done the progressive monotubes, the JRI remote reservoir rear shocks, the beefier engine mounts from Glide Pro. I haven't done the stabilizer just yet... But I had some pronounced wobble at the beginning of the season last year.
Turned out it was the tires I swapped to. I run Agitator 18" & 18" on my motorcycle, and I wanted to go back to Metzler. I had Metzler on the stockers [and still do - they're on the shelf in the garage]. Anyhow I thought "Of course I want Radial Tires..." apparently not.
I talked to the Metzler rep at Sturgis, and he said our heavy motorcycles require bias play. Secondly the rear tire turned into a racing slick after 7000 kilometers. Sure I have a 120R but 7000 k?? Whiskey Tango Foxtrox???
So now I'm runnin' just good ol HD Dunlops. I've done a few speed tests, and they do just fine at 125 mph. Illegal yes, but you gotta know right?
No not through corners, but straight stretches I'd get the wobble going with the Metzler radials. I am a bit of a tire pressure nut too. I ran them at the 38/40 and higher like 42/42, 42/48 etc just to test.
I agree with Graham [grbrown] re:stabilizers and re-read his post earlier this week. But The tires can have a big effect too.
My buddy on a new '15 FLTRXS had a good wobble coming home. He was bone stock in the tire suspension arena...
Come on spring...
fl-flhx
Dec 14, 2009 03:15 PM
Mario77746
Feb 25, 2009 08:48 AM
bigdaddy405
Aug 28, 2008 04:32 PM
twiceretired
Jul 3, 2007 10:36 AM
lawdogso
May 21, 2006 09:21 PM
