Anyone else's sprocket look like this?
Old Aug 31, 2015 | 12:05 PM
Keithhu's Avatar
Keithhu
Default Anyone else's sprocket look like this?
30K miles, 2013 FLTRU.
Old Aug 31, 2015 | 12:49 PM
GTK's Avatar
GTK
I have only half the miles on my 2013,but my rear sprocket looks like new.My guess from looking at the picture is that you have been running belt too tight and off center to sprocket.One good thing is that it is easier to replace sprocket than a belt.
Old Aug 31, 2015 | 12:50 PM
journeyman's Avatar
journeyman
nope
Maybe a factory defect?
Old Aug 31, 2015 | 01:03 PM
skid_pimp's Avatar
skid_pimp
Yup have a sprocket hanging on my wall that looks very similar. Had a new tire installed at the dealership right before I came home from overseas, as I had a big ride planned. They installed the belt way to tight, and the rear wheel was 1/16 out of alignment, which is technically ok, but I normally do my own and do it perfectly. The tight belt causes that wear, and the off alignment can cause the belt to wander back and forth, which it looks like yours did. Never mind the additional tire wear...
Keithhu's Avatar
Keithhu
Belt deflection as measured by the window in the belt guard has always been right in the center. Is that too tight?
Old Aug 31, 2015 | 01:21 PM
Loc_Tite's Avatar
Loc_Tite
Any chance you ride on salty roads in the colder months? Mine looks a little like that and that's what I chalk it up to.
*edit* never mind I was looking at the pic on my phone and when I looked closer I see it's mainly on the one side. Mine looks bad evenly across.
Old Aug 31, 2015 | 04:54 PM
grbrown's Avatar
grbrown
Wink
There is a very useful deflection tool for checking belt tension, the one H-D tool worth having! It's the best way to check tension IMHO, which it does by pressing upwards on the belt by a measured amount. You check how much it moves by looking through that window. Well worth checking tension and setting it right, if necessary.
Old Aug 31, 2015 | 05:25 PM
Keithhu's Avatar
Keithhu
The window has lines, isnt the point of it to have the deflection be basically in the middle of those lines? I need to check my manual.....
But I'm still puzzled as to what causes what I'm seeing on the rotor. Would a too-tight belt cause it? The tech wasnt sure, he speculated "hard riding". I doubt its that.
Old Aug 31, 2015 | 06:40 PM
ohioflhs's Avatar
ohioflhs
Mine has looked like that for several years now with apparently no adverse affects. It looks like chrome peeling off mine. They say to change belt and both sprockets as a set. I will go with the bigger rear sprocket when I do mine.
Old Aug 31, 2015 | 07:01 PM
Jethro's Avatar
Jethro
I also had a belt showing the same wear. Never amounted to any problem, and the belt finally wore out at 75,00 miles (missing ribs), and replaced both as a set.
