HELP! Removed ign switch, unlocked it, now wont lock back in
Old Sep 3, 2015 | 10:23 AM
Greek Power's Avatar
Greek Power
Originally Posted by HDJIM1158
I feel your pain.... been there. All I can say is take a break, re-read the manual and start over. Make sure the bars are turned to the left, seem to be the trick for me.
Good Luck, JIM
What HDJIM said. Turn bars to the left position.(the fork locking pos.) Align the two tumblers the same way as the ingnition shaft is at the fork lock pos. Drop it in. There is a hole at the bottom of fork plate with a detent hole in it. The ignition pin at the bottom of ign., must line up to that hole. --mike GREEK POWER!
Old Sep 3, 2015 | 10:24 AM
sanman4ever's Avatar
sanman4ever
Originally Posted by SteveUltra
I have found that you do not have to turn bars all the way to the left when taking the switch apart. I point he bars straight ahead and I leave the switch in the straight ahead position, pointed at off. (NOT FORK LOCK) Put key in **** and use a small screwdriver to depress release tab on bottom side of ****. With everything pointed straight ahead it is much easier to work on bike. Also when you go to put the **** in the switch it is easy to remember that everything is pointed straight ahead.
This seems like the way to go?
Also homemade tool never worked on my 09 either. Always just used a screw driver.
Old Sep 3, 2015 | 12:57 PM
rpking's Avatar
rpking
I knew there had to be an easy way, just put the switch back into the hole easy peasy
Old Sep 3, 2015 | 02:27 PM
hardheaded's Avatar
hardheaded
my homemade tool worked very well on my 12 and alot of other bikes i used it on.
Old Sep 3, 2015 | 08:39 PM
bagman1's Avatar
bagman1
Thanks to everyone for the advvice and suggestions. I looked at the tabs which are actually the same size, but ine side is a square tab and the other is the same except it has a beveled edge against the shank. My eyes arent as good as they used to especially looking in a little hoe with a light. Made what I thought was 1 click CW, dropped it in, turned and removed key and the forks locked. Unlock with key and try all positions and hit the starter in ON and she works.
I will get or make a tool after my road trip, even if I never remove it again, I wont be worried because I have the tool!
Old Sep 3, 2015 | 09:02 PM
lp's Avatar
lp
Very glad you got it figured out finally. That is a pain...
Next time though, just take the ignition switch out while the forks are centered, then take off the lower/center console off or whatever you're trying to get at, and then put the ignition switch right back in without touching another thing.
This way you never need a "tool" and you can move your forks back and forth if you need to while you're working.
Old Sep 3, 2015 | 09:06 PM
sanman4ever
Originally Posted by lp
Next time though, just take the ignition switch out while the forks are centered, then take off the lower console off or whatever you're trying to get at
You think you can get the fairing cap off with the forks in the locked position?
Old Sep 3, 2015 | 09:15 PM
lp's Avatar
lp
Read what I typed again. Forks centered.
Forks don't have to be physically locked to the left to pull the ignition switch.
Old Sep 3, 2015 | 09:18 PM
sanman4ever
Got it, forks straight. Thanks
Old Sep 3, 2015 | 09:21 PM
acchd's Avatar
acchd
bagman1 glad to hear you got it worked out brotha! Just FYI the Craftsman 5/16 x 6" slotted screwdriver fits perfectly for ignition tool.
http://www.craftsman.com/craftsman-5...ype=SKIP_LEVEL
