New pipes and filter are on but need a map
Old May 3, 2007 | 02:06 AM
chfcheese's Avatar
chfcheese
Default New pipes and filter are on but need a map
Received my Vance and Hines Oveal slip ons, Arlen Ness Big sucker and PC# usb. I got the PC3 from Fuel Moto but there was no map installed. Iinstalled the closet one that was listed but it was the SE air cleaner vice the arlen ness. Should I try and get a different map or will this one work. I sent Fuelmoto an e-mail but they say 72 hours. I need to ride to work in the morning should I be fine for now?
Old May 3, 2007 | 02:18 AM
Gunkholes's Avatar
Gunkholes
Default RE: New pipes and filter are on but need a map
I think you'll be OK until you get the correct map from Fuelmoto. The difference in airflow thru the SE & the Arlen Ness shouldn't vary enough to make a significant change in your mixture. Call Jamie if you have any problems -- he's pretty responsive.
Old May 3, 2007 | 10:07 PM
chfcheese's Avatar
chfcheese
Receieved a reply back from Jamie at Fuel Moto. He said that the map had to be loaded and that there would be no notes on there. My question is it said no map at the bottom of the screen. Is there a way to still pull up that map after I installed the similar map? Seems to be running ok so far with the current map, but would like to have the correct map installed.
Old May 3, 2007 | 10:18 PM
fxlowboy's Avatar
fxlowboy
Do you plug the USB cable and the 9 volts battery ??? do you see green light on the pc3.
Old May 3, 2007 | 11:29 PM
hd2007's Avatar
hd2007
Make sure you set the throttle position , it is very important , or it will not run right until you set it.
Old May 4, 2007 | 01:37 AM
chfcheese's Avatar
chfcheese
I used the bike power and the usb cable. I never checked the lights at all, but the computer recognized everything on the computer. I did set the 0 throttle as well do i need to do the max throttle? It says it's not always necessary
Raytron99
Jul 20, 2013 12:30 PM
jordanball33
May 25, 2012 07:26 PM
flhtupser
Apr 28, 2009 10:01 PM
marksv4
Aug 10, 2008 06:09 AM
Dogs of war
Feb 9, 2007 10:01 AM
