Shifter link broke...
Old Sep 9, 2015 | 02:14 PM
harkon's Avatar
harkon
Originally Posted by rhuff
Not sure how well this pic shows it.... I guess it doesn't really, but the bottom right of the pic, where the main bolt goes thru....on the other side of the linkage (bottom joint).....am I missing a part? For the life of me, can't figure out if I'm missing something or I just can't get the clamp opened up to snug on the spindles....regardless, bike goes in next Wednesday for a speaker that blew and will have them fix it. Will likely be ordering the heim joints tho ASAP.
I had the heel / toe shift levers coming loose off of the splines regularly. Looking at it, it seems impossible that with the relief in the splined shaft and the bolt shouldering in that relief it would be impossible for the lever to even come off, but it most certainly would. I ended up putting blue locktite on the splines as well. On a trip a month ago, in the middle of nowhere, the inboard lever came off. The bolt was still tight in the lever part, but it simply worked it's way off the end of the shaft. Good thing I had my feet on the boards at the time and not on the highway pegs, I might have lost parts. I put blue locktite on the splines and bolt and reinstalled and it's good now as well. I don't know if it's the vibes or what, but mine eventually would just work their way off the end of the splines. I thought I was the only one, but it looks like I'm not.
Old Sep 10, 2015 | 06:38 AM
patrick74's Avatar
patrick74
Just had mine replaced. The spline has a lot of groves which makes the metal thinner... When looking at the part they took of there was a flat spot wore off on both the shaft and the lever.
Old Sep 10, 2015 | 08:12 AM
hardheaded's Avatar
hardheaded
you need to remove the bolt completely before installing the shift arm. holding the back of the shifter shaft install the arm all the way and then put the bolt in. while you have it off inspect for any damage.
Old Sep 10, 2015 | 10:43 AM
Leftcoaster's Avatar
Leftcoaster
Correct me if I'm wrong but it appears that you've lost the inside bolt that holds the inner arm to the splined shaft.
I'm not referring to the toe/heel arms, but the arm that's closest to the front cylinder that connects to the linkage that goes back to the transmission.
Replace that bolt and you're golden. A little blue Loctite will also help.
Old Sep 10, 2015 | 10:50 PM
sn95bullitt's Avatar
sn95bullitt
Mine snaped in half on a freeway interchange. Rode 30 miles in 3rd gear to Harley and bought a new one. It was a great beginning to my trip to Santa Cruz.
Old Sep 11, 2015 | 11:07 AM
rhuff's Avatar
rhuff
What I was thinking. Just didn't know what or if anything was there. Will get the "warranty" fix and dealer and then figure out how to make the whole deal stay put. And get a service annual for this bike too.
Old Sep 11, 2015 | 01:57 PM
Cpl Ed's Avatar
Cpl Ed
Originally Posted by kryingame
On my 2012, my shifter link broke just as I was leaving the NC mountains. Popped right off and I was not able to repair it. I had to get a tow. The stock ones are made of aluminum. Why won't Harley make them chrome, especially since this is a constant known problem.
Just a thought..... how silly would it be if someone just drilled and tapped a small hole on the end of the shaft. Then screw a small washer onto the end. (Washer slightly larger diameter than the shaft)? Probably 'overkill' but would keep arms from falling completely off. Oh well, probably a dumb idea.
TimLScheffer
2014-2024 Touring Models
29
Sep 23, 2017 04:18 PM
Moondogger
May 16, 2017 05:59 PM
Gunnysgt
48
Apr 15, 2016 01:56 AM
fastolds
Aug 4, 2008 12:31 AM
grzly
Jan 25, 2008 08:27 AM
