Garage Ideas
Old Sep 22, 2015 | 11:02 AM
Eagle240's Avatar
Eagle240
coming from an old garage that didnt have much electrical.... always found it helpful when i installed 3 retractable extension crop cords on the ceiling. there was never a reason to run a extension cord to center of garage from wall... justpull from above!
Old Sep 22, 2015 | 11:11 AM
hattitude's Avatar
hattitude
I built a small shop for my Harleys last year, about 350 sq ft.
Made sure it had a couple of 220V breakers. Currently one is in use by the compressor and the other is HVAC.
Gotta have a rest room.
I even painted it HD colors, white, black, & orange.
Once outfitted it, I have only one regret......
I didn't sink the lift table into the floor.....
I park one of the bikes on the lift, to save space.
In my small shop, a sunken lift table will certainly help out with space issues....
When I switch bikes on the table, out come side extensions and ramps. If I leave them on, they take up room. If I take them off, I gotta store them somewhere handy... still take up room.
But more than space issues... The table sits 8" above the floor when fully collapsed.
If the bike were dead, like my Ultra, I would need help pushing it up the ramp.
My table goes to 40", so if I sunk it flush, it will still raise 32"... like many lift tables... good enough for me.
I am going to sink it into the floor this winter. It will cut done on time/effort to switch bikes on the lift and will allow me to push a broken bike up the lift single-handed if ever necessary.....
Good luck, you'll love it however you set it up...!
Old Sep 22, 2015 | 06:04 PM
oc1014's Avatar
oc1014
Nuff said
Old Sep 22, 2015 | 06:12 PM
Florida Swamp Yankee's Avatar
Is this for parking or working in?
Sounds like it's big enough for both! Do you fabricate/weld or do hot work? Do you paint or do body work? Ventilation away from the "clean" side might be a consideration.
Are you in a wet or snowy area? A continuos slot or trench drain to outside is something else to think about.
Run extra conduits across from one end to the other with a 4sq box every 15-20 ft. no smaller than 3/4".
And don't forget a sound system!
Old Sep 22, 2015 | 06:27 PM
Robjr's Avatar
Robjr
Default Garage Ideas
Nice garage hattitude
Old Sep 22, 2015 | 06:45 PM
Time Machine's Avatar
Time Machine
Just a little thing, but run a nice bead of polyurethane calk between the floor and wall and finish it wit a 1/2 inch radius before painting the floor. It will save having to sweep or vac a crack.
Old Sep 22, 2015 | 06:46 PM
Jaystn62's Avatar
Jaystn62
For lighting I would go LED. Much brighter and in long run much cheaper. Shop around.
Old Sep 22, 2015 | 06:47 PM
WrayZor's Avatar
WrayZor
Got a blank canvas, paint it ur way!
Old Sep 22, 2015 | 06:49 PM
miami's Avatar
miami
I put all benches and other heavy items like compressors on castors. this way it makes cleaning easier, i have a motorcycle dolly for easy moving around. remember when you drop something it will always roll under something
Old Sep 22, 2015 | 07:36 PM
quadrcr87's Avatar
quadrcr87
Fist off congrats on the new garage. I would recommend you check out my second favorite site www.garagejournal.com. There are a ton of great ideas to be incorporated. I have provided a link below to the motorcycle garage thread as well as my own garage. A great tool for designing is google sketchup. I shared a screen shot of mine below.
Couple Ideas:
Shelf for helmets and other gear with a coat rack below
Plenty of strong work surfaces near motorcycle lift
Portable cart or table to roll to your work area
Retractable lights, ext cords, and air
Paint to match your bike
Frame some of your favorite car or bike photos
Whiteboard to track projects or parts on the wish list
http://www.garagejournal.com/forum/s...ight=quadrcr87
http://www.garagejournal.com/forum/s...rcycle+garages
