Road King Shocks Leaking Oil
Old Oct 15, 2015 | 06:00 AM
tigercreek's Avatar
tigercreek
$60 dealer take-offs on the way.
If I decide to keep the bike I will probably move up to Ohlins or Progressives.
My experience with all of Progressive's gear has been positive.
Old Oct 15, 2015 | 10:04 AM
Notgrownup's Avatar
Notgrownup
I just changed the oil to 10 wt in my rears after 85000 miles, they are now better.
Old Oct 15, 2015 | 12:07 PM
tigercreek's Avatar
tigercreek
How do you go about doing that?
Old Oct 15, 2015 | 03:07 PM
Notgrownup's Avatar
Notgrownup
Threaded barb fitting and a mity vac... suck it all out and put it back in with a syringe.
Old Oct 15, 2015 | 05:28 PM
cmstewart72's Avatar
cmstewart72
Upgrade. You'd be surprised how much your ride can improve. I replaced the stock shocks with Progressives and am SO glad the stockers went out.
Old Oct 16, 2015 | 11:18 PM
Fishrrman's Avatar
Fishrrman
Probably the easiest fix for leaking factory shocks is to replace them with a take-off set. Had that happen on my 2000 Road Glide years ago.
I happened to be at Americade, stopped by the Progressive shock area and they gave me a set, free!
Old Oct 17, 2015 | 05:21 AM
Notgrownup's Avatar
Notgrownup
The stock shock is fine with me, yeah I might enjoy Ohlins or Progressive but for now I will save that money. The fresh oil in the shocks and forks improved the ride. Maybe 1 day but after 90000 miles with them on there? The stock ones are staying. I spent that money on a new seat.
Old Oct 17, 2015 | 10:35 AM
bigheadted's Avatar
bigheadted
Before you bolt them on drain and replace the fluid, there are many threads here on how to do it.
I gravity drained them first time by removing the fitting and hanging upside down over a bucket.
I used a horse syringe to fill then by finding a needle that fit tight in a small length 2" of the air line, injecting the new fluid about a half syringe load at a time.
Easy and cheap and boy what a big improvement over what was in there.
FWIW I used some synthetic ATF.
Old Oct 19, 2015 | 11:36 AM
tigercreek's Avatar
tigercreek
Sounds like a plan.
customglide57
Jun 8, 2015 05:05 PM
CharruaHD
Nov 11, 2012 05:19 PM
lowriderbob
Jan 2, 2012 08:13 PM
schultzy60
Feb 18, 2010 04:36 PM
lusodom
Feb 11, 2006 01:24 PM
