Speedometer Acting Weird!!
Old May 5, 2007 | 02:46 PM
robbitybob's Avatar
robbitybob
Default Speedometer Acting Weird!!
Ok so Mama and Itook a ride this morning and when we were heading back I glance down at the speedometer and it reads like 40mph. The trouble is I was going at least 55 maybe 60. I don't seem to have any other symptoms. Any ideas about whatmight begoing on? Thanks
Old May 5, 2007 | 02:58 PM
Timex's Avatar
Timex
Default RE: Speedometer Acting Weird!!
Sensor in top of tranny might need cleaning/replaced.
Old May 5, 2007 | 04:48 PM
robbitybob's Avatar
robbitybob
I took my ride for a ride and the speedometer was just fine - not a hic-up anywhere! This is weird
Old May 5, 2007 | 05:04 PM
dougbk's Avatar
dougbk
Speedo sensors are known for going bad, due to the metal filings in the transmission building up on them.
Old May 5, 2007 | 06:06 PM
berettag's Avatar
berettag
My 2000 Ultradoes that on occasion. Stop, andstart her up again and she works fine.
Old May 5, 2007 | 08:00 PM
robbitybob's Avatar
robbitybob
Thanks - I guess I won't worry about it then, until it just quits for good.
Old May 5, 2007 | 09:16 PM
Zimbob's Avatar
Zimbob
My '02 Sporty did the same thing, i just pulled in the clutch, turned it off, started it back up and all was fine.
Old May 6, 2007 | 08:21 AM
Fearless1's Avatar
Fearless1
My 99 roadking speedometer has been wierd since I bought it took it back 3 times and still got the same problem. Sometimes I start her up and have no speedometer at all other times she will read 4 miles an hour at 55 and other times it will read 15 miles an hour at 55 I have even had it jump to 120 and stay there as long as your moving and it racks up the milage at the level the speedo is reading. I got tired of setting at the dealers on my days off trying to get them to fix it so now I go by my internal speedo in myhead and haven't gotten a ticket yet. I pass a speedo trap machine (shows you your speed)everyday going to work and back and I can usually hit the speedlimit within a mile or 2 an hour every time.
Old May 6, 2007 | 08:40 AM
plamb's Avatar
plamb
Bob - I struggled with the same problem for months...
Cleaned the speed sensor - worked fine (for a while).
Replaced the speed sensor - worked fine (for a while).
Checked, cleaned, and dielectric greased all conncections - worked fine (for a while).
Found some loose grounds and tightened everthing - you get the idea.
It kept getting worse - it affected the stereo volume, the odometer, and according to the wiring diagram it was probably making the fuel injectors send the wrong amount of fuel to the engine.
I finally took the originaly speed sensor, cut off the connector, and ran new wires to the speedometer. That solved the problem for good. Seems as though I had a (nearly) broken wire somewhere that just needed to be replaced.
Good luck. You'll get it eventually!
Lunchboxx
Electrical/Lighting/Alarm
Oct 1, 2016 09:28 AM
19JMan70
Apr 11, 2014 06:03 PM
mays
Jul 28, 2008 07:12 PM
hammon
Jun 9, 2008 06:44 PM
Zutroy
May 3, 2007 03:11 PM
