Checking Trans fluid?
Old Oct 18, 2015 | 10:52 AM
harley0711's Avatar
harley0711
Default Checking Trans fluid?
Is it me and I just getting Old? LOL
Just changed the Trans fluild on my 15 Ultra - Boy, its hard to see the new clean trans fluid on that little dip stick.
new location and new way to check level "screw in until o-ring touches but do not tighten - check level???
new clean fluid very hard to see - am I alone on this? LOL
Old Oct 18, 2015 | 11:29 AM
shadowchrome's Avatar
shadowchrome
Use Redline Shockproof next time. You can sure see that!
Old Oct 18, 2015 | 11:35 AM
Gwaxley's Avatar
Gwaxley
Harley0711, I have a 14 limited with the same engine as you. I do all my own serving, stage1 install, Yaffe bars and replaced my cams. Although this is my first Harley I do a lot of reading and ask alot of stupid questions lol.
When I change oils, and I change all oils every 5000 miles I add 3 1/2 quarts to the engine, 1 quart to the trans, and 38 ounces to the primary.. And I don't even check the levels, I'm confident I have no leaks and I filled the correct holes with the correct oil I planed to. Also I never even check the oil between changes, if there is no leaks and no serious blow by (oil dripping at the air filter) the oil levels are good..iv got 22000 miles now, after you have done this a few times you will be confident also.
I read another of your posts asking about oil in the trans and primary being the same oil, in the new 103s they are totally separate but I have a 09 sportster 883 and the oil in the trans and primary are together. Meaning when I change the primary oil ( that is where the drain plug is) im changing the trans oil also.
Greg
Old Oct 18, 2015 | 11:41 AM
jaxdwg's Avatar
jaxdwg
My book says stand bike up, check level without screwing in the cap. Just put in dipstick till it makes contact.
Old Oct 18, 2015 | 12:01 PM
harley0711's Avatar
harley0711
Ya, thats what I am used to.
2015 = ROOM TEMP - bike on kickstand - remove dipstick - clean - screw in till O-ring touches...
Old Oct 18, 2015 | 12:02 PM
btsom's Avatar
btsom
The back side of the dip stick is smooth. Rotate the dip stick and you can see the "bulge" of oil on the stick. Then rotate it back to where you can see the level reference mark and compare. It helps if the stick has been wiped dry before the measurement is taken.
Old Oct 18, 2015 | 12:03 PM
harley0711's Avatar
harley0711
Shadow / Greg = both great advice, thanks...
Old Oct 18, 2015 | 12:07 PM
harley0711's Avatar
harley0711
That is what I did - several times - hard to see - new/clean oil and new dipstick... lol - getting old
Old Oct 18, 2015 | 12:20 PM
mikeo33y's Avatar
mikeo33y
Greg
what he said. measure out proper amount. pour in. done deal. although i do check for peace of mind. never had a problem. i agree. on trany stick, its super hard to see. i have to bring it outside and spin it around in the sun with my specs on to see oil on the stick.
Old Oct 18, 2015 | 11:50 PM
wscott's Avatar
wscott
I use spectro's trans oil (75/140) they specifically mfg'g & formulated for HD's 6 spd trans thats a nice red color & very easy to see.
Don't feel bad,i am pushing 60yrs old so i am close to being an old fart too!/LOL!!!
See below for info & link for info on the spectro trans oil for 6-spd HD trans.
Scott
http://performanceoilstore.com/products.asp?cat=65&pg=4
Spectro Heavy Duty Platinum 6-speed Transmission Oil 1-qt
Designed by Spectro in response to complaints from Harley owners about the great but noisy new 6-speed transmission, this full synthetic provides ultimate lubrication protection. Formulated to significantly reduce gear noise and provide easier, smoother shifting, this SAE 75w140 formulation eases shifting even when cold. High loads and extreme heat do not affect the oil, so it performs well when pushed hard and long. A.P.I. GL-5 rated
