Bat Wing accent panel switch
Old Oct 20, 2015 | 04:59 PM
GTK's Avatar
GTK
Default Bat Wing accent panel switch
I have a 2016 SGS that I am looking for a switch to go in the black accent panel where the ignition switch is located.I cannot locate one online from Moco.Has anyone used a aftermarket switch that fits in the panel slot or can provide the HD part number?I am installing a HD fog lamp kit that mounts on the front guard and the switch that is in the kit is not for the accent panel.
Old Oct 20, 2015 | 08:07 PM
Nitroharley's Avatar
Nitroharley
Just a guess but could it be a 71535-96?
Old Oct 21, 2015 | 08:35 AM
GTK's Avatar
GTK
Part number does not show on HD web site,Thanks anyway
Old Oct 21, 2015 | 08:47 AM
J929626's Avatar
J929626
Hopefully this will help:
FWIW, the switch bases for the right and left side are the same. The switch buttons are different. The base part number is 69200173.
Part No. Description
69200172 SWITCH ASSEMBLY auxiliary/fog lamps, w/ 67200173, 71400031 & 71400044
69200173 SWITCH, DASHPANEL, BASE
71400031 SWITCH BUTTON blank
71400044 SWITCH auxiliary / fog lamps Left Hand
71400109 Accessory switch, LH (ACC)
Harness
71400105 DASH PANEL KIT w/ 71400031, 69200173, 71400109 (2)
71400106 DASH PANEL KIT w/ 71400031, 71400109 (2) NO SWITCH BASE
CVO
71400032 SWITCH ASSEMBLY fog, w/ 71400031, 71400034 & 71400037 (CVO) Left Hand (LH)
71400033 SWITCH ASSEMBLY lock/unlock, w/ 71400031, 71400035, 71400036 & 71400037 (CVO) Right Hand
71400034 SWITCH BUTTON, ILLUMINATED, FOG LH CVO
71400035 SWITCH BUTTON, ILLUMINATED, LOCK
71400036 SWITCH BUTTON, ILLUMINATED, UNLOCK
71400037 SWITCH, DASHPANEL, BASE (CVO)
More info in this thread:
https://www.hdforums.com/forum/new-r...tch-flhtk.html
Old Oct 21, 2015 | 02:36 PM
GTK's Avatar
GTK
Thanks Road Master
Old Oct 21, 2015 | 07:51 PM
Nitroharley
https://shop.newcastlehd.com/part/71535-96
New Castle Harley has it. $27.57
It's the standard switch that H-D used as accessory switches. Not sure if the shape matches what you're looking for.
Old Oct 22, 2015 | 07:43 AM
GTK's Avatar
GTK
Thanks Nitro,
Old Jun 16, 2021 | 09:23 PM
Bible44840's Avatar
Bible44840
3rd Gear
Default Switch button #71400044 fog light button insert.
Harley davidson fog light insert button that goes in the left side bank housing. Part no.71400044
netmeister
2014-2024 Touring Models
70
Oct 21, 2021 09:15 AM
Dragonback
Electrical/Lighting/Alarm
Oct 27, 2015 12:40 PM
Crueguru
Aug 26, 2014 11:00 AM
Gunnysgt
11
Mar 29, 2014 11:13 AM
rwrimes
Jun 16, 2011 09:50 PM
