71718-02 Auxiliary On/Off Switch
Old Jun 15, 2011 | 08:28 PM
rwrimes's Avatar
rwrimes
5th Gear
Default 71718-02 Auxiliary On/Off Switch
Can anyone tell me if the Auxiliary On/Off switch, P/N 71718-02, can be used as a "momentary switch" for activating the garage door opener?
Old Jun 15, 2011 | 09:34 PM
firedog341's Avatar
firedog341
Won't be momentary. Have to flip it on and off. If you have an empty spot you can install a CVO Momentary switch P/N 71764-07. Harley uses it for electric saddlebag locks.
CVO Momentary Switch
Old Jun 15, 2011 | 09:57 PM
Potato_Potato's Avatar
Potato_Potato
People have used the switch that operates the tour pack locks on CVO models. It is momentary. You can also use an odometer reset switch.
Old Jun 15, 2011 | 10:02 PM
mkguitar's Avatar
mkguitar
or if you have some smarts you can use a relay on for instance the high beam circuit,--- hit the high beam and the door moves.
plenty of info on the garage door mod here:
https://www.hdforums.com/forum/touri...s-to-save.html
mike
Old Jun 16, 2011 | 07:58 AM
rwrimes's Avatar
rwrimes
5th Gear
Thanks for the responses.
I have an 08 Road King Classic and was going to get the handlebar mounted Black Auxiliary Accessory Switch Housing, P/N 70248-02B, and thought maybe the Auxiliary On/Off switch, P/N 71718-02, could be used in doing this. I'm not interested in wiring the garage door opener to the head light high beam as the HD instructions call for in their door opener. I've been looking at using one of my spare remotes to wire it into the switch I'm asking about. I've seen where many folks on this forum have done some pretty creative things, but no one has done it with the switch housing I'm buying for other accessories.
I believe I'm going to try the Trip Reset Switch, P/N 67488-04, and the Reset Switch Boot, P/N 67880-94, that Potato Potato mentioned to mount in one of the spare covers on the Auxiliary Accessory Switch Housing, P/N 70248-02B.
Any thoughts or more suggestions are certainly welcome.
Thanks again.
Old Jun 16, 2011 | 08:41 AM
69cj's Avatar
69cj
Harley Davidson switch - $52.00
Radio Shack Standard duty switch - $3.00
Grainger's Industrial grade switch - $12.00
I went with Grainger's. Included the weather proof boot.
Old Jun 16, 2011 | 09:19 PM
slyder's Avatar
slyder
I used my aux switch and a 12v starter relay (since my opener remote was not 12v) to operate my garage door opener.
Old Jun 16, 2011 | 09:50 PM
vickers1's Avatar
vickers1
I use this switch with the rubber boot. This is a 2 way because I have 2 garage doors that have to be opened when I get home. Up opens one door and down opens another.
Get them at any boat or marine store. About $5.00
Attached Thumbnails 71718-02 Auxiliary On/Off Switch-marine-switch.jpg
netmeister
2014-2024 Touring Models
70
Oct 21, 2021 09:15 AM
GTK
Jun 16, 2021 09:23 PM
Dragonback
Electrical/Lighting/Alarm
Oct 27, 2015 12:40 PM
Crueguru
Aug 26, 2014 11:00 AM
Lylemonroe
Jul 26, 2013 02:52 PM
