HELP...Cold start issues good battery
Old Oct 21, 2015 | 06:48 PM
gioss's Avatar
gioss
Question HELP...Cold start issues good battery
Ok I have a 09 ultra, 255 cams, power commander V with auto tune, etc... If its low 30's farenhiet the bike will not cold start. This is year 3 and no one can tell me why. Battery is fresh and tenderd. i hit the start button and it may pop once while cranking but will not fire. It cranks normally for a minute or two until the battery eventually drains. Once the bike gets close to 40 degrees it starts right up. Its as if the coil doesnt spark in the cold. Has left me stranded at my girls house after the temp drops overnight. My buddy a mechanic ran into another similar bike with the same issue. I need to ride my bike all year, my gal lives in manhattan and needless to say there is no parking for cars....
Please help....
Old Oct 21, 2015 | 06:56 PM
chief08's Avatar
chief08
on the power commander can't u richen up the cold start?
Old Oct 21, 2015 | 06:59 PM
gioss's Avatar
gioss
My dealer told me the V doesnt. Perhaps someone knows how?
Old Oct 21, 2015 | 07:37 PM
jaxdwg's Avatar
jaxdwg
A shot in the dark here: get some starting fluid and give her a shot on those cold mornings. If it starts, "perhaps" your model has an inlet air temp sensor that controls start mixture, that may be erroneous at low temps. They make an inline plug tester that will show you if it is getting spark, while still sparking the plug in the engine. That way you can confirm or eliminate the coil idea. Just thinking out loud !!! I may be way off base, but, I'm not seeing any other ideas just yet.
Old Oct 21, 2015 | 07:42 PM
jaxdwg's Avatar
jaxdwg
Here's another thought: put a 75 watt bulb near the coil on those cold nights, to keep the temp above that 40 line. Fixed?-- get a coil. If not, point the light at the air filter area and try that. Again, just a thought.
Old Oct 21, 2015 | 07:55 PM
wscott's Avatar
wscott
LOL.you beat me to it!
I was going to suggest he check the same 2 items.
Scott
Old Oct 21, 2015 | 08:17 PM
bbest71's Avatar
bbest71
I had a similar problem on my 2010 RK. I ended up putting a 60watt lamp under the oil pan and seemed to help but didn't solve the problem...I went to a lighter weight engine oil too. But what I really think was my problem was a weak starter...the starter clutch went bad for the second time and said hell w it...I installed a new starter and she fires right up now! Only have 40k miles...Got an aftermarket all ***** starter on Amazon for $220. Good luck.
Old Oct 21, 2015 | 09:50 PM
jaxdwg's Avatar
jaxdwg
Scott
Are there stock or aftermarket plugs in it ? If aftermarket, put in the good old stock plugs and try that. Aftermarket iridium type plugs may run cooler, but in cold weather, a hot spark may mean the difference in starting or not. When it won't start, have you checked to see if the plugs are fouled or dry?
Old Oct 22, 2015 | 12:55 PM
gioss's Avatar
gioss
I have not tried to check the plugs. I believe they are stock, harley put them in. All great ideas, thanks. I will gather intel once it gets cold again....
notnutts
Jan 25, 2020 06:38 AM
Halverson19
Jul 19, 2016 11:37 AM
prostreetdon
May 22, 2013 08:36 AM
eric91379
Mar 25, 2008 10:59 AM
basarabz
Dec 15, 2007 06:21 PM
