Almost lost it! Need help please
Old Oct 22, 2015 | 08:52 PM
MNPGRider's Avatar
MNPGRider
Here's a thought....With the low miles on your bike, when were the tires last replaced?
You might be riding on very old tires.
Old Oct 22, 2015 | 09:02 PM
EasternSP's Avatar
EasternSP
What is it, cost to much to just put the month and year information there instead of some cryptic code that everyone will be able to figure out anyway.
Old Oct 23, 2015 | 08:39 AM
Joe12RK's Avatar
Joe12RK
since this is a sudden problem, it's probably your tires; maybe you picked up a nail? or it could be tread separation or something internal. but it wouldn't hurt to check the other things mentioned above.
Old Oct 23, 2015 | 08:47 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
It's also possibly the section of the road you were on. Especially if they've grooved to for repaving.
Old Oct 23, 2015 | 08:54 AM
cprhed's Avatar
cprhed
I am a support engineer and every time I get a case for support issues on something that was working fine and suddenly misbehaves I always first ask, What has changed.
The description you give, combined with the note that you inflated tires just before the ride instantly would narrow my search to begin with the tires, then the wheels. You may find as suggested by others that there was a loose bearing or mount or something and that whatever happened with the tire/wheel was just enough to act with the other out of spec item to cause your event. Sort of like bad motor mount and has been bad but showed no symptom, then you inflated tire and tire got out of balance or something and the two worked in unison to cause the behavior. Might be simple enough.
My basic troubleshooting tells me you should start with the wheels/tires.
That said, I am glad that you made it safely despite the "interesting" journey.
Old Oct 23, 2015 | 09:59 AM
THE PEG's Avatar
THE PEG
The spokes are done. Bet some are broken. Tires are probably 10 years old. There was a service recall on the front motor mount. Think maintenance or have problems.
Old Oct 23, 2015 | 10:06 AM
Hogpro's Avatar
Hogpro
Former Sponsor
I'd check for loose spokes first.
Old Oct 23, 2015 | 10:41 AM
mervt198's Avatar
mervt198
Could it be wheel balance. Does it go away when you hit a higher speed?
Old Oct 23, 2015 | 12:28 PM
SilverEagle50's Avatar
SilverEagle50
Not knocking you there merv, but that damn thing wobbling like that, I'm not going to gas it and see if it gets better or not. just saying...
Old Oct 23, 2015 | 12:35 PM
mrfikser's Avatar
mrfikser
don't forget to check the wheel bearing.. they are notorious for going bad and if the bearings suddenly broke loose a fell out that would explain what happened...
