Primary fill and Comp problems
Old Oct 25, 2015 | 07:46 PM
Lowcountry Joe's Avatar
Lowcountry Joe
I am convinced the deflector logic is plain bull ****! The compensator parts spin, spin induces centrifugal force, centrifugal force slings lubrication AWAY from critical areas where it is needed from the spindle outward. Most of the lube in the primary is pushed back toward the clutch plates. Splash lubrication of a constantly spinning part is an ineffective lubrication solution. A failing lubrication strategy for the compensator parts has been proven over the years by the many sporadic failures of HD compensators. And after all this time, nothing much has changed.
Old Oct 25, 2015 | 07:55 PM
perki48's Avatar
perki48
Originally Posted by Nomadmax
On a cold start I pull the clutch in, put it first and back the machine up until I feel the plates separate. Then I start in neutral with the clutch in and put it back in gear. This is only the first cold start of the day.
All I do is pull the clutch in and start the bike. If I do not release the clutch prior to putting the bike in gear it NEVER clunks on first start up.
Old Oct 25, 2015 | 08:50 PM
wscott's Avatar
wscott
Originally Posted by mikeo33y
I was looking at several diagrams of the factory fill level on the primary of twin cams. The factory fill level seems to be at the bottom of the clutch plates in every diagram ive seen. if you follow a straight edge to the left towards the compensator, the oil level seems to be well below the bearing and everything that needs lubing. If you just pour in 38 ounces of primary oil like the service manual recommends, the the oil level is at the clutch spring and actually almost coming out of the derby cover hole and this is after a thorough drain. now if u run a straight edge over to the compensator, the comp. is much more submerged in an oil bath. Many folks dont have comp issues after 50. 60. 70 thousand miles or so. im wondering if there is a connection here. However. if you fill your primary this high, to the clutch spring, ive noticed louder clunking when shifting. Any thoughts on this?
Too much oil in prim causes clutch to have even more issues fully releasing thus causing a louder clunk sound when shifting
unless you use much thinner ATF that allows clutch plates to release better then proper prim oil does but is questionable when it
comes to longjevity / protection of IPB etc.
Thats why i installed GMR's compensaver (when replacing bad comp at 10k miles with new SE comp kit) to ensure the compensator is properly oiled at all times.
Doing that allows you to 38-40oz prim oil refill lvl when doing prim oil change srv'c without having to cause other issues overfilling prim case in an attempt to introduce additional oil to the compensator to extend it srv'c life.
I have put approx 8k+ miles on the new SE compensator and compensaver with no issues thus far with either of those items.
Scott
Old Oct 26, 2015 | 07:18 AM
Campy Roadie's Avatar
Campy Roadie
Is it neutral Perk?
Old Oct 26, 2015 | 07:20 AM
Campy Roadie
I've read a lot of your posts Joe. I've kinda been waiting to see if you're going to install a Baker unit. If you do, I'd be interested in hearing about it.
Old Oct 26, 2015 | 09:54 AM
*Road King*'s Avatar
*Road King*
I'm installing the Baker unit. Just waiting for it to arrive.
Old Oct 26, 2015 | 11:40 AM
perki48's Avatar
perki48
Is it neutral Perk?
Yes it is, I start in neutral with clutch pulled. Then put it in gear and start riding. This only works on cold start though. After that you must hold clutch in a bit longer.
Old Oct 26, 2015 | 11:57 AM
btsom's Avatar
btsom
For the OP: I understand the machines used by the Motor Cops for the maneuvering demos and contests are over serviced mostly for cooling the clutch which is slipped more than average for the low speed maneuvering. The shop manual gives over servicing as one reason for trouble getting into neutral. I over service mine a few ounces, definitely not to where the lube almost runs out the derby cover hole with the bike upright. I have 62000 miles on my owner installed SE Mark I comp and all seems well.
For LowcountryJoe: Have you looked closely at the latest version comp? It takes advantage of the centrifugal force you mention. The hub area has 6 lube flow holes drilled at an outward angle as they extend from right around the mounting bolt head and go into the inner hub area. Some of the oil slung around the case by the chain is caught and dripped onto the center of the compensator by the oil catcher cup and centrifugal force should sling that oil into the hub area. The earlier design comps don't have those holes and are prone to run dry in the inner hub area. Engines eventually wear out, and I assume these latest compensators will eventually wear out also. Anything made by man etc....
Old Oct 26, 2015 | 12:15 PM
Campy Roadie
I'm gonna give that a try. Thanks
skyhawk940
May 6, 2014 01:49 PM
Retrop
Sep 3, 2013 09:50 AM
elev8rguy
EVO
28
Jun 30, 2012 11:28 PM
manny10
Shovelhead
Jun 19, 2012 04:51 PM
Big Sled
May 13, 2012 07:55 AM
