Touring Shocks
The super shox motorcycle shocks look to be a decent product that seems to have good feedback from bikers that bought them.
Might be a good idea to start a new thread after you get the super shox installed , test ridden & dialed in to let us know how they perform.
Scott
Many shocks mentioned offer only two types of springs, standard and heavy duty. This is the same for valving, only two flavors per spring type ordered. Worse yet, same valving with a stiffer spring or softer spring. Hence, people say the shocks are too stiff for them. For the same amount of money, or less money then some shocks mentioned, you can get a shock custom built. Ohlins or Works. Maybe Terrys - dont know. Ordering a shock that is longer will also help A LOT in ride quality, more suspension travel. Even going from a 12" to a 12 1/2" will be noticeable if 13" is too tall for rider or you want to keep the lowered stance look.
I ride the twisties spirited, prefer ride quality and increased lean angle, and went with 13 1/2".
Can anybody add some insight, or decoding. There is mono-tube, emulsion. I don't know how many letter designations?
What does it all mean to my day to day ride?
But for a simplified version:
Howard's #2 series=significantly better than stock and better than or equal to
most aftermarket shocks.
Howard's # 3 series=significantly better than Howard's #2's
Howard's #6 series=even better than the #3's
They are stiff. I'm going to give it 500 to 600 miles before I call DJ or George to adjust them.
They are much better than factory air on my 05 ultra. I even changed the fluid on my factory air and put a valve in each shock to eliminate lines and fittings.
I can tell you a better back end will really magnify a poor front end.
I have progressive monotubes ready for install when I get time (thanks HogPro!)
Coworker has #6 ohlins with rezzies from Howard. He is still dialing them in as well.
I think the best thing to do is call a few people, gauge your level of comfort in talking to them and go from there.
I am certain Howard has a fine product. I also know his attitude and demeanor are very similar to mine. I didn't go with Pro-Action for price, I went with them to try something different and from a company who has been in the suspension business a long time.
Think about how boring it would be if the MoCo only made 2 or 3 bikes, and the only color was vivid black.
Mrs B and I have #3s and we can travel further each day in greater comfort than ever before, yet still feel we can carry on. Our Ohlins have removed ride comfort from the things that limit how far and often we ride. The shocks give a smoother ride and have never bottomed out, regardless of what we have hit. Our all-up rolling weight on trips is close to the bike's max.
