Six speed in a Road King???
Just curious,whats approx rpm on your bike in 6tht gear @ only 50-55mph?
That seems to me like 50-55mph in 6th gear would be lugging the motor which is not as much of an issue cruising at 2k rpm (maybe 2,100-2,200rpm) or so in a lower grear like 3rd or 4th but not so good to lug the motor at maybe 2k-2,100 rpm in high / 6th gear which is why i am asking what rpm the motors at.
And another thing to consider is if your cruising in for example 6th gear at 50-55mph at 2k-2,100rpm where the motor has less trq/pwr can actually reduce fuel mileage vs running in lower 5th gear at maybe 2,400rpm-ish at the same 50-55mph speed where the motor is better positioned in its trq/pwr curve which can get better mpg in this example.
When the motor is hot (esp on hot summer day) also has lower oil pressure at 2k-2,100rpm vs 2,400-2,500rpm which is also something to consider if the motors being lugged at 2k-2,100rpm in high / 6th gear .
The lowest rpm i cruise my stock 96" at when i am loafing along on flat roads with just me on the bike in slower traffic in 3rd or 4th gear is 2,250-2,300rpm and 2,350-2,400rpm in higher 5th or 6th gear.
Anything below those rpms in those gears & the 96" motor on my bike doesnt like it .
Cruising at the minimum or bit higher cruise rpms i stated above with most of my riding 2 up my bike avg's 41.5-42mpg in mixed driving 20-25% city & 70-75% more open road cruising out in the countryside at 55-62mph (5th gear @ approx 2,600-2,700rpm & have got as high as 44.5-45mpg when cruising by myself of course being conservative riding on my part for best mpg.
Scott
The cost of adding a six speed tranny will not make any difference at highway speed. It will help the bike get up to speed a little better. But it would not in any way justify the cost.
I've had so many guys tell me so many different things about the factory 6 speed that it only leads me to believe that few people have much of an idea what they're talking about.
My riding buddy has a 2010 Ultra with a factory 6 speed in it and my Dyna has a stock 5 speed in it...Now pay attention.
At 80 mph riding side by side in top gear, his rpm is exactly the same as mine.
I'll repeat it for you...
Edited to add: As far as getting up to speed faster, My 95" motor runs away from his 103" stage 1motor with 6 speed like it's parked.
My 99 visited 48 states between 99 and 08 often running 75mph all day. The 5speed is fine and up to the task.
To the OP - a pulley swap sounds more in your budget.
