battery tender
Old Nov 13, 2015 | 09:50 PM
hardheaded's Avatar
hardheaded
now that i hear this i believe it does have a five year warranty. i have six of these things going all the time and would like to get more than three years out of them. i'll call them and see what they have to say.
Old Nov 13, 2015 | 10:01 PM
Thingfish's Avatar
Thingfish
Optimate 3. These things will keep your battery alive for up to 8 years. Doesn't just tend battery, it cycles and tests it. About $65 but worth it.
Old Nov 13, 2015 | 10:14 PM
nocarb's Avatar
nocarb
I use the Optimate also 3, 4 and 5's. Great products. This reminded me to plug the bike in.
Old Nov 13, 2015 | 10:50 PM
Fishrrman's Avatar
Fishrrman
OP:
Are you using a "pigtail" type connecting cord on the battery?
That you then plug the tender's cord into?
If so, check the battery pigtail cord carefully.
I have a Schumacher battery maintainer. I was getting an error message from out of nowhere. Upon close inspection, I found that one end of the pigtail cord had a bad connection (where it connects to the battery itself).
I replaced the pigtail cord and it's been fine since.
Old Nov 13, 2015 | 11:00 PM
tnriverluver's Avatar
tnriverluver
Originally Posted by Fishrrman
OP:
I have 4 of the Schumakers (all less than a year old) and had one go bad. Wallyworld replaced it after some fuss although it was only 2 months old. The bad thing I have noticed about these is no matter how low the voltage drops after it charges they will not go back to charge mode unless you unplug them and reset them every now and then. I ran a battery down to 11 volts trying to crank one bike while the tender was plugged in and it never went back to charge mode even after several hours of waiting. I will be replacing these with a different brand soon.
Old Nov 13, 2015 | 11:01 PM
From_Behind's Avatar
From_Behind
I've had one go bad before. Bought a new one. Problem solved.
Old Nov 14, 2015 | 06:44 AM
todd-67's Avatar
todd-67
Autoparts store a few bucks and forget about it.
Old Nov 14, 2015 | 06:50 AM
Larry Davis's Avatar
Larry Davis
All of my Deltrans have a 10 year warranty. A couple of years ago they did not hesitate replacing one of mine that stopped working.
Old Nov 14, 2015 | 08:14 AM
smitty901's Avatar
smitty901
Things do go bad. I have a couple HD tenders around here I know it says HD on it must be junk. One lays around out side I use it on the ATV, mowers anything that needs it been laying around out side winter spring ,summer and fall for about 4 years.
Still good as new.
Old Nov 14, 2015 | 08:17 AM
Campy Roadie's Avatar
Campy Roadie
Check the fuse in the tender pigtail attached to the battery. Maybe save yourself a little money.
