Tach question?
Old Nov 26, 2015 | 08:16 AM
Flintshooter54's Avatar
Flintshooter54
Default Tach question?
Ok so taking a spin on the bike yesterday to check out my Baker Comp install I noticed something strange to me. I was in the lower gears running up through the RPM range paying attention to sounds or lack there of. That stock Comp was the root of several strange noises in my motor. Anyway I have the Fuel Moto 107 kit that Jamie put in. They set the red line at about 6,200 RPM. The motor pulled hard up to the rev limiter, but the tach needle stopped cold at 5500 RPM. So I tried it aging to see if I saw things right. Yes motor kept pulling past where the needle stopped. Now I have to admit I have only bounced off the limiter a couple times on this bike and while doing so was watching the road and not the tach. But this don't sound normal to me. Bike is a 2010 Limited 103 with FM 107 kit. Is it standard for the tach to stop or do I have an issue? Maybe a sending sensor or whatever drives the tach.
Old Nov 26, 2015 | 09:15 AM
bigdumbnoitall00's Avatar
bigdumbnoitall00
pcv will do that remember reading some older post mack in 09-10.cant remember if there was a fix but it was due to the pcv.
Old Nov 27, 2015 | 07:48 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
On Power Commanders TBW models with RevXtend ebabled the PC-V drives the ignition above 5200 rpm and the tach stops just over 5k
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Nov 28, 2015 | 04:11 AM
Campy Roadie's Avatar
Campy Roadie
It's always something when it comes to modifications. The trouble is, you don't find out what "something" is until after you're committed.
Old Nov 28, 2015 | 07:41 PM
Flintshooter54
Thanks guys. Just so that is standard operating and not something broke I can live with it. I don't run up there much anyway. If it is a product of the PC V then it has been that way for years and I never knew it. Even when getting on it I shift at 4,500-5,000 max anyway.
Robeuro03
Mar 27, 2011 04:19 PM
flight
Mar 28, 2010 11:06 AM
Mountainkowboy
Jan 24, 2010 08:37 PM
Magos
Apr 3, 2009 06:19 PM
easyglider
Mar 21, 2007 08:54 AM
