Handlebar Question
Old Dec 1, 2015 | 04:44 PM
Cozz's Avatar
Cozz
Default Handlebar Question
What are the tallest handlebars that can be used with the stock wiring and cables. I feel like the stock bars make me slouch after a short time, which makes my neck and upper back ache.
Old Dec 1, 2015 | 05:57 PM
Keithhu's Avatar
Keithhu
Choose the handlebars that are most comfortable and buy the required cables that go with it. Its completely silly and short sighted to let cable length be the limiting factor on comfort, even more so if its on a bike on which you plan to put a lot of miles.
Besides, the stock cables look like ***.
Old Dec 1, 2015 | 06:00 PM
Buelligan666's Avatar
Buelligan666
Old Dec 1, 2015 | 06:22 PM
somorkc's Avatar
somorkc
Cheap solution, I used 08 heritage bars. Comfortable solution, KST 16 inch Mayhems. Put the heritage bars on for six months until I could upgrade the cables, wires and bars.
Old Dec 1, 2015 | 07:50 PM
apexeric's Avatar
apexeric
I apologize in advance for the thread hijack.
I purchased an 2006 Ultra Classic last year. It is my first Harley Davidson. I put these Heli Bars on mine because I was having the same issue as you describe. While they helped me a lot, I still feel like I need more reach back.
So now I am curious about how to get longer bars and how to go about getting longer cables and wires.
http://www.helibars.com/products/Hel...Glide/610.html
While I understand that longer throttle cables and clutch cables are available, I am curious about the brake hoses and the electrical wires.
Nice derby cover!
Old Dec 1, 2015 | 07:53 PM
bgdv1's Avatar
bgdv1
10" bars are max with stock wiring and cables. I have 10 LA Chopper bagger bars on my SG and would go any higher without cables and wires.
Old Dec 1, 2015 | 07:55 PM
Iceman24's Avatar
Iceman24
^^^Ditto^^^
Did mine (10" LA Choppers), but ended up getting a longer clutch cable to route back through batwing portal.
Old Dec 1, 2015 | 08:10 PM
Cozz's Avatar
Cozz
Thanks for the links. Very informative.
Old Dec 2, 2015 | 02:05 AM
NELS's Avatar
NELS
Had the same problem and solved it by using risers and a street slammer cover . It was posted by another member some time ago
Old Dec 2, 2015 | 11:02 AM
Bowhunter61's Avatar
Bowhunter61
Originally Posted by Iceman24
^^^Ditto^^^
^^^ Ditto Ditto ^^^^^
Just put 10" Wild1 Chubby's on mu Ultra, no way I would or could go higher without replacing the cables or extending the wiring.
