crankshaft flywhheel
Many years ago a local dealer had on display a con-rod with the bearing journal jammed tight in it, removed from the flywheels. I think it was out of a Matchless single; the rollers had ground down against each other, then climbed over each other until the whole lot welded itself together. The owner had ridden his bike until it finally stopped, engine seized thanks to that rod bearing. Despite that the engine was dismantled and rebuilt, the flywheels were fine!
Going back to Greg's crank, ride it until the engine obviously needs attention. That can be any of a number of things, for example burning oil, making a lot of noise, vibrating, etc. Your question is rather like another common one - how long does a belt last?! There really is no easy answer, but a very long time, if you're lucky - in both cases.
Zach
I'd say if his crank scissors, it would have anyway.
