What I learned from Fuel Moto
Old Dec 8, 2015 | 08:49 PM
kryingame's Avatar
kryingame
Default What I learned from Fuel Moto
Men, I learned something today from Bob at Fuel Moto. I want to pass this info on to those with the Power Vision Tuner.
A week or so ago, I programmed and selected several gauges to display of the PV. After 10 minutes or so of riding, the gauges stopped working. I called FM and asked why. Bob asked how I was running the PV and that was the problem.
I routed the wire on the left side of the bike, under the tank and near the spark plugs. This is a problem because the wires are not shielded and while I was riding, the wires were catching interference from the spark plugs.
According to Bob, the gauges weren't able to display properly. He even said, running the wire this way will cause issues with AutoTune basic.
His advice is to run the wire underneath the dash console. That way there will not be any electrical interference.
Hope this information helps some out there.
Old Dec 8, 2015 | 08:52 PM
FNGonaRK's Avatar
FNGonaRK
I pulled the tank and ran the wire in the cable trough with the rest of the wiring. Everything works fine and it took maybe 10 minutes and three new zip ties.
Old Dec 8, 2015 | 09:59 PM
Gilmb's Avatar
Gilmb
Thanks kryingame, I did the same thing when I installed new cams and map. I thought I had reduced performance when I ran autotune basic so I put the original map fuelmoto sent me. Thinking i was just doing a temp install for a couple of auto tunes, I ran it on the left side like you near the plug wire. Not touching but close. I will reroute it in the spring and try again.
Old Dec 8, 2015 | 10:05 PM
JMC22's Avatar
JMC22
Good info to know and I'll check my set-up when it gets back from the painter - thanks for sharing....
Old Dec 9, 2015 | 08:07 AM
skratch's Avatar
skratch
you did have reduced performance. when you are running autotune, the af mixture is set to 14.6 across the board, and app 4* of timing is pulled out.
Old Dec 9, 2015 | 09:01 AM
kryingame's Avatar
kryingame
Actually, Bob said this is a common mistake. They often get folks calling in complaining about this. I guess we're all looking for the easy way to route the wire.
I now have my wire underneath the gas/key console. Took about 2 minutes to do.
Old Dec 10, 2015 | 09:39 AM
Gilmb's Avatar
Gilmb
I should have been more clear, I felt I had reduced performance after loading the map created during the autotune session.
DrewBone
17
Jan 13, 2019 06:27 PM
pdevore
Feb 21, 2016 06:51 PM
jimfount00
Nov 4, 2015 05:14 PM
Bat
Exhaust System Topics
Apr 21, 2009 05:53 PM
coop57
May 7, 2008 05:18 PM
