Led laid light
Old Dec 16, 2015 | 09:32 PM
star2nv's Avatar
star2nv
Default Led laid light
Has anyone here used one of the cheep led tail lights from ebay?
Old Dec 16, 2015 | 10:24 PM
NODYNA's Avatar
NODYNA
I have in the past and recently. The older ones worked well with no early failures. The latest orders aren't fitting in the sockets tightly and disconnect easily. I have not taken the time to see what I can do to get a tighter secure fitting in the socket. Probably worth the extra bucks to get a name brand in the future. Walmart is now stocking LEDs at reasonable prices.
Old Dec 16, 2015 | 10:47 PM
dyna rider's Avatar
dyna rider
Default Plug Security
I installed a cheap LED light a couple of weeks ago that had a plug that fit the factory harness but was very loose. I plugged it in and put a tie wrap around both sides of the connectors so it couldn't come apart.
I had to cut the same tie wrap when the light didn't work correctly as it was wired wrong from the factory.
Old Dec 17, 2015 | 08:26 AM
bigheadted's Avatar
bigheadted
you could always but a dab of adhesive silicone at the joint of the connections in a couple spots, let it cure and it should be fine.
I learned when you buy the cheap stuff you end up buying it again or something quality to replace it when it goes out. I hate pissin my hard earned and little to spare $$ so I wait and get the good stuff.
The BAL is so worth the $$
Old Dec 17, 2015 | 08:51 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
OP, are you talking tail light assemblies, or just a replacement bulb?
Old Dec 17, 2015 | 09:50 AM
star2nv's Avatar
star2nv
I'm talking tail light assemblies
Old Dec 17, 2015 | 11:15 AM
batman.'s Avatar
batman.
contact custom dynamics for led bulb replacements. Lifetime warranty and are bright as hell.
Batman
Old Dec 17, 2015 | 11:59 AM
lt1-xjs's Avatar
lt1-xjs
I run this, works great. http://www.radiantz.com/Laydown-with...00254-hdtl.htm
Old Dec 17, 2015 | 12:19 PM
UUNetBill's Avatar
UUNetBill
Two words: Custom. Dynamics.
Old Dec 17, 2015 | 06:03 PM
star2nv's Avatar
star2nv
This is what I'm looking at
taz944t
Oct 9, 2018 11:30 AM
babaharley
Mar 17, 2018 07:02 PM
hdbikerg08
Jun 4, 2016 07:18 PM
jim h
Apr 11, 2013 01:36 PM
medic1555
Aug 4, 2011 10:12 AM
