How do air shocks work
How do they work?! Reasonably well solo, less so when 2-up, or if the rider is heavy. They have poor damping, so IMHO ride quality is marginal. Unfortunately H-D fits cheap shocks across the entire range and you will find tons of suspension threads all around HDF. Hence there is an enormous market in aftermarket stuff, to improve the ride!
Hope that helps. (Satisfied customer of Howard!).
But... I'm having a hard time trying to wrap my head around this mounting them upside down thing!
It seems they don't fit with detatchable tour pak or passengers backrest.? They get mostly good reviews but not much mention about mounting them this way. I called and they said it makes no difference. Maybe it's just me but I'm also looking a bit higer up the price scale, Pro-Action and then Olhins at the top.
This image might help. While it is a standard automotive shock, it works well enough for illustrative purposes:
Under that green outer cap is where the metal coil springs live. All well and good.
Now, put an air tight seal around that green outer cap at the bottom. As the shock goes up, the space gets smaller and the air gets squished, creating pressure. That's how the stock air over Showa shock works without any added air.
Now put a fitting on the top of that green outer cap so we can run an air line and pump up pressure. With it pumped up, there is increased air pressure at the fully extended position, as well increased pressure when the shock is compressed.
Because the metal coil springs take the load, the air is just supplementing the load capacity, which is why the pressures are quite small.
Unlike the use of say the Monroe air shock where the metal coil springs are removed and the air is the sole thing carrying the load. In that case, the air pressure has to be quite a bit higher in order to hold the motorcycle up.
I changed my SGS shocks cause they were to stiff for my weight (140lbs) but i thought the bike handled great. I've read the Progressive's have the same issue with being stiff for lightweight riders, which is why i chose to go with something that is sprung specifically for the riders weight.
The twin tube example fetured in the movie is no where as poor quality as the air shock found on your Harley.
How does a BILSTEIN shock absorber work? (monotube vs. twintube) - Shock Shop 2011 - YouTube
One would think with that many parts in a cheapo shock..it would be cheaper to put a well balanced spring shock less all that air hardware...I just don't get it... HD would make so many new friends.
If the whole shock is pressurized (around 0~50# PSI) how would spring pre-load work or the only function of air pressure would be to compress the spring (spring pre-load)?
There are many things that make a great shock work.
- Reduced stiction (friction) so the shock can move relatively easy & reduced rubbing so the shock can actually work. More money is spent on developing a shaft, (seal head with seals & bushing), and piston ring along with seperator piston ring. Let us not forget oil. All oils are not the same as far as reduced friction.
- Design of the shock, materials, and piston design.
- Correct valving for the rider.
- A spring on a great shock is only chosen to hold the bike up and equalize the gravitational pull of the earth making the bike, passenger, and load equal zero. The shock controls bike and not the spring. There is no light, medium, or heavy duty spring. There is only one spring & that spring is the exact spring that can be adjusted to fit your application range. Riders preference also plays on how his bike should feel to the rider.
- Ability to control the bike and riders sag which means that the bike must have a rebound stroke to go down into the hole without moving the frame. More friction, more the frame will be dragged down through stiction.
- Unfortunately, you only know what you have experienced. Sometimes it pays to ask questions from someone who actually knows how something works and not someone giving an uneducated opinion in a field they are unqualified to give.
I bought a set of Ohlins 2-2(A) from Howard and I know now I made the right choice. With the HDF member discount that Howard provides, the shocks weren't that much more than the nicer Progressives. And the Ohlins were built for my specs and riding style.
The decision is ultimately yours, but just pointing this out.
(Another satisfied customer of Howard)
