Heated grips
Old Jan 2, 2016 | 10:13 AM
Lsc8's Avatar
Lsc8
I'd say that plug was supposed to go to the lh grip pictured. Doesn't look anywhere near long enough to reach. It has 2 up 2 back easy reach bars.
I'm thinking either the extension was lost or they never fixed the wiring for this set of bars.
I don't see what looks like any clearace work on the switch housing.
Also looks like a few wire rubbed raw on the grip. ...
Not sure if I should buy a new grip and fix this side or just say f it?
Never had heated grips, but thought they were already there and it'd be a cheap fix
Old Jan 2, 2016 | 06:38 PM
IKnowNot's Avatar
IKnowNot
That would be where it goes.
I am guessing you are missing the wire harness 70282-08.
But they are beyond repair, and someone knew it.
You see those three wires cut off just at the top of the chrome ring?
They are the ones I said should normally be run outside the bars, then down under the tank for power.
Yours are cut off.
If you replace with new heated grips you will have to re-wire the left side of the bars.
The right side too if the test I described for them failed.
Old Jan 2, 2016 | 07:04 PM
Lsc8's Avatar
Lsc8
I actually found the wiring...I believe. Has the orange wire, red tapped into the factory plug, and ground.
Just couldn't stop chasing the rabbit. Smh
I guess if I splurge the hard wiring is done....maybe...I think...smh
Old Jan 3, 2016 | 07:15 AM
jdw1's Avatar
jdw1
This might help or might not help, idk.
http://www.harley-davidson.com/app-c...ts/-J05296.PDF
Hatrick
May 2, 2017 06:04 AM
eglide_rider
Feb 10, 2016 03:50 PM
DonCMcC
2014-2024 Touring Models
Apr 4, 2015 06:53 PM
WooHaaSG
Mar 30, 2015 01:03 PM
uscanuck
Feb 20, 2011 12:26 PM
