Changing front turn signals
Old Jan 21, 2016 | 10:50 PM
Larry the Landlord's Avatar
Larry the Landlord
Default Changing front turn signals
I want to get rid of the stock turns and driving lights. Wanting to mount the signals to the forks. I have looked into street glide signals. Ideas?
Old Jan 22, 2016 | 06:41 AM
RKZen's Avatar
RKZen
Try Custom Dynamics here http://www.customdynamics.com/truflex_truwraps.htm or DK Customs. They'er a big sponsor in the Sportster forum http://www.dkcustomproducts.com/Mult...ED-FTS-UNI.htm. There are others out there.
Old Jan 22, 2016 | 07:36 AM
Magnut1's Avatar
Magnut1
What kind of bike do you have>
Old Jan 22, 2016 | 08:01 AM
BuzzL's Avatar
BuzzL
I changed mine out. Not hard to do, went with HD parts, definitely looks better, if you do the front you need to do the back as well so it will balance out. Everything you need is in the HD accessories catalog. One thing leads to another, you will then need to change your license plate bracket if you do the rear assuming you have a bagger with a tour pak. +1 on Custom Dynamics.
Old Jan 22, 2016 | 12:56 PM
Larry the Landlord
Sorry, it's a 2002 Firefighter Road King.
Old Jan 22, 2016 | 02:54 PM
DK Custom Products's Avatar
DK Custom Products
Sponsor
The DK Custom Products Stealth LED Front Turn Signals/Running Lights are pre-wired with 4 Posi-Lock connectors, you simply screw the 4 connectors into place, no cutting, splicing, soldering or taping of wires will be necessary.
The Stealth LED's come standard 4.5" long or 5.75" long. The 4.5" works well with fork tubes that are 39mm; for 49mm forks and the fork covers found on Softails and Touring Models the 5.75" work best.
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
emperor wurm
Aug 30, 2015 09:17 AM
Bigdaddy89
Shovelhead
16
Oct 2, 2012 04:12 PM
ace57
Nov 18, 2010 09:40 PM
oddtodd
VRSC Models
Dec 17, 2007 09:41 AM
Gunkholes
May 6, 2007 10:44 PM
