Chirping Rinehart True Duals
Old May 10, 2007 | 02:47 PM
Corndog's Avatar
Corndog
Default Chirping Rinehart True Duals
I put Rinehart True Duals on my 07 RKC and they put out a high-pitched chirp. The chirping is pretty loud and sometimes goes away. The tech guy at Bub said this happens now and then and they suggest that I buy quieter baffles to make the chirping livable! Any body else out there experience this?
Old May 10, 2007 | 02:53 PM
FLHT's Avatar
FLHT
Default RE: Chirping Rinehart True Duals
I've heard this talked about before. If I remember right someone was saying to use some WD40 on the rubber mount under the bags where the mufflers hang that this will sometimes make that type of noise. If that doesnt do it I would double check all your connections to make sure you dont have an exhaust leak.
Old May 10, 2007 | 02:56 PM
madurodave's Avatar
madurodave
Are they taking lessons from the MoCo?
"That noise is normal". "Just live with it".
It's not right!
Old May 10, 2007 | 03:02 PM
ckgdrums's Avatar
ckgdrums
Yeah, mine do that too. I've just kind of gotten used to it. Checked all the connections...everything is tight. Just a weird noise, I guess.
Old May 10, 2007 | 03:31 PM
hotpursuit's Avatar
hotpursuit
i dont believe it is the pipes... get new bushings, the sound will disapear...
Old May 10, 2007 | 03:32 PM
ken thompson's Avatar
ken thompson
The Schlong Man
Mine SE touring muffs chirp, rattle and buzz too. For the ongest time I thorugh it was the liscense plate. I've had that thing off a dozen times and right now has about 20 of those little green felt pads all of the back of it. Turns out its the muffs. I'll try the WD40 thing.
Old May 10, 2007 | 04:04 PM
TexasRedneck's Avatar
TexasRedneck
Try some silicone lube...it's thicker an' will last longer.
Old May 10, 2007 | 04:16 PM
gordo24fan's Avatar
gordo24fan
I remember in another thread someone saying something about taking out baffles and hitting a notch in the end to take them just slightly out of round.
Old May 10, 2007 | 04:31 PM
tduff's Avatar
tduff
My pipes are doing this also. The service tech at the dealership I frequent says he thinks he can adjust the baffles so that sound may go away. I think I am going to take them out and give it a try myself.
Old May 10, 2007 | 04:35 PM
SoCal_Pappy's Avatar
SoCal_Pappy
WD 40 the rubber sliders on the mufflers\bracket also check the mouunting bolt on the left header pipe...
