Air cleaner housing
Old Feb 3, 2016 | 09:11 AM
smalls78's Avatar
smalls78
Default Air cleaner housing
Do all aftermarket air cleaners stick out further? I'm running an aftermarket filter that uses stock housing cover but sticks it out prob 2 inches now.
For just running a catless header, slip-on mufflers, and PowerVision...do I even need the aftermarket air cleaner? Does anyone use stock or maybe the K&N replacement filter?
Thanks for feedback.
Old Feb 3, 2016 | 09:37 AM
GTK's Avatar
GTK
If your aftermarket air cleaner is wider than the stock HD one,it stands to reason it will stick out more.
Old Feb 3, 2016 | 09:47 AM
smalls78's Avatar
smalls78
Lol, captain obvious. I should've rephrased my question;
1. Are there slim aftermarket air cleaners anyone is using?
2. Does anyone keep the stock AC (or maybe use the K&N)? If so, any noticeable difference?
Old Feb 3, 2016 | 10:00 AM
grbrown's Avatar
grbrown
It would help us to know which filter you currently have. The stock airbox is actually a muffler, as well as providing a mounting for the filter element. Simply replacing the stock housing with a flat backplate will increase noise and airflow. The SE filters usually get rid of the stock airbox and the last one I had didn't seem to be any deeper, it also used the stock cover. Take a look at #29400233.
Old Feb 3, 2016 | 10:02 AM
Dezz's Avatar
Dezz
I felt a big improvement in performance w/ my aftermarket cleaner (big sucker) vs my stock filter. What air cleaner are you using?
I also didn't like it sticking out further at first but I recently got floorboard extensions and the difference is night and day, much more comfortable.
Old Feb 3, 2016 | 10:05 AM
smalls78's Avatar
smalls78
Fuel Moto air cleaner using stock cover
Old Feb 3, 2016 | 10:42 AM
OldPhat's Avatar
OldPhat
I use a K&N filter in my stock ac housing (K&N part #HD-1614) plus a DK Customs breather kit.
It works good and more then likely will supply more air then my engine can use, Just saying.
Old Feb 3, 2016 | 11:25 AM
billablehours's Avatar
billablehours
I don't find that mine sticks out any further than the stock one and flows more than enough.
http://www.harley-davidson.com/store...18-29400230--1
Old Feb 3, 2016 | 01:19 PM
DK Custom Products's Avatar
DK Custom Products
Sponsor
The DK Custom Products Outlaw 587 A/C System is a low profile design to give you the best leg clearance. The 587 is a complete system that features K&N air filters and 6 different breather options to allow you to vent crankcase gasses to atmosphere instead of routing them back in to the A/C improving performance and engine longevity.
Multiple covers and rain socks are available to give your bike the exact look you're after.
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
Old Feb 3, 2016 | 02:35 PM
smalls78's Avatar
smalls78
^ This!
Thanks DK
