Dash mount oil temp gage
Old Mar 11, 2009 | 02:04 PM
  #51
Ghosty's Avatar
Ghosty
I was going to replace my air temp gauge with the Harley oil temp. gauge but when I went to order it the parts guy at the dealer asked if I was moving to the south. I said no and he said "why are you installing the temp. gauge". He said that here in the northwest a temp gauge is really not needed. He also said if I had about $150 bucks I wanted to throw away he'd be happy to order the parts for me. Well, I thought it over and decided he had a point. The parts guy said if I was going to be traveling to the southern U.S. in the summer and staying there for more than two weeks a temp gauge might be a good idea. This type of advice is one of the reasons I like my dealer here in Tacoma.
Old Mar 11, 2009 | 09:24 PM
  #52
05 Ultra's Avatar
05 Ultra
Originally Posted by 09StreetGlider
Ever figure out what it was that made the gauge rest to the right? Was it the speakers? Any fix for it?
I'm installing the McEwen Gauge as soon as it gets here and would like to know the fix before I close up the fairing in case mine does the same.
As a matter of fact I did. It was the Hogtune speakers. Since I moved the volt gauge to where the temp gauge was and put the oil temp gauge where the volt gauge was, the magnet was too close to the gauge and pulled the needle over. I swapped it back to the old spot. Problem gone.
Old Mar 11, 2009 | 09:37 PM
  #53
09StreetGlider's Avatar
09StreetGlider
I figured this one out a few days ago...it may seem like its the speakers but believe it or not it isn't. Has something to do with the polarity of the wiring harness. Instead of installing the gauge I tried it while holding it my hand away from the speakers and it rested to the right. So then I went and looked at the wiring book and figured out instead of using the harness the instructions said to use I could use the other one. I think the said use the 2 wire and I used the 3 wire harness (or vice versa). Anyway when I used the other harness the gauge immediately rested to the left. After I installed the gauge it has not gone to the right again. And the gauge is still on a switched circuit via the ignition so it's not draining juice all the time. I have Hogtunes as well and the oil temp gauge is in the top right spot right next to the speaker.
Old Mar 12, 2009 | 11:42 PM
  #54
dkitch's Avatar
dkitch
need help installing oil temp gauge anyone got step by step directs and pics would be nice the harley directions blow my mind guess i'm one of those dumb cavemen. thanks
Old Mar 13, 2009 | 12:08 AM
  #55
ArgyleRider's Avatar
ArgyleRider
Default Still Want to Know
Thanks for all the good advice and pointers. I am going to do this mod before summer hits.
I may not be able to do too much about oil temp (change speed, pull over and stop...find a shady oak tree and have a beer?), but I still want to know.
Old Mar 13, 2009 | 01:16 PM
  #56
racklefratz's Avatar
racklefratz
Typical "parts guy". There's a reason why they're behind the parts counter and not somewhere else that requires actual knowledge.
You don't spend all your time fixating on the oil temperature, but its value lies in establishing the baseline oil temperature for your engine. Once you understand the range of temps normal for your bike, you're in a position to spot abnormalities. If you notice the oil temperature is unusually high, you have reason to suspect something's going on, like low oil quantity, detonation, worn rings permitting blow-by, etc. Likewise, it's useful to be able to see low oil temp as well. After a cold start, the oil isn't circulating optimally, it's a good idea to avoid hard acceleration until temps come up to normal.
Using the oil temperature gauge to spot deviations from the norm can help in identifying developing problems before they become severe. And this technique works anywhere you ride.
[edited to change "low temp" wording]
Old Mar 13, 2009 | 02:27 PM
  #57
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
You don't spend all your time fixating on the oil temperature, but its value lies in establishing the baseline oil temperature for your engine. Once you understand the range of temps normal for your bike, you're in a position to spot abnormalities. If you notice the oil temperature is unusually high, you have reason to suspect something's going on, like low oil quantity, detonation, worn rings permitting blow-by, etc. If it shows way below what you expect, your oil pump may be going. Using the oil temperature gauge to spot deviations from the norm can help in identifying developing problems before they become severe. And this technique works anywhere you ride.
Thanks for pointing that out.Makes sense.
Old Mar 13, 2009 | 02:50 PM
  #58
caspr2's Avatar
caspr2
All I'm getting when I type in your wally world link is a bunch of freaken spam. If that is how they do business I don't want anything to do with them.
Old Mar 13, 2009 | 04:12 PM
  #59
Ridewva's Avatar
Ridewva
Thumbs down
Be aware of an issue with (at least some of) the current HD oil temp gauges. There is a space on the outer dial face, behind the glass which allows the back light to make a distinct halo. I took the gauge back and the dealer ordered another one. I could see even in the box that it was made the same way so I didn't even take it. It's more noticable on the black gauges than the silver ones. I contacted HD and even furnished pictures. They said the oil temp gauge was now coming from another supplier and "that's the way they are now." Maybe I'm too picky but having four symetrical gauges with one illuminated differently just bothered me, especially at night. So I ended up putting the air gauge back in and wrote it off as a $125 mistake.
Old Mar 13, 2009 | 04:19 PM
  #60
09StreetGlider
Wally's is now Direct Harley Parts...here's the link. http://www.directharleyparts.com/websitelinks.asp
I got mine from them but I suggest following your order up after a day or so because they were a little slow shipping it. Good Gauge though...
Here's my write up on it...pros and cons to both gauges. But easy install.
McEwen_Oil_Temp_Gauge
