Hi, just ordered a King Tour Pack color matched for my 2015 Roadking. Dealer didn't know if it comes pre-drilled on the bottom to accept the mounting rack. Anyone ordered the newer packs that would know? I'm a little tentative about drilling such an expensive item. thanks
** PARTS LIST **
King Tour Pak # 53000399XX XX = Paint Code
2014 Detachable Rack # 53000221
Key Matched Barrel Lock # 90300030
Screw Pan hd #8-32 x3/8 Torx Drive # 10200062 x 2
King Tour Pak Backrest Pad - Smooth # 52300312
* EXTRAS *
Premium King Tour Pak Fitted Liner - Bottom # 53000323
Smoked Side Marker Light Kit # 54352-09
Cover, Tour Pak Wiring # 53000308
Screw, Truss Head Machine # 2724 x 2
Nut, Acron # 90844-80 x 2
Yes pre drilled for the mounting rack, back rest and all hard wear included, except lock and the screws to mount the lock. So when you order the lock make sure and order the mounting screws.
Just incase you did not know.
