Hot off the dyno
Old Feb 14, 2016 | 01:04 PM
  #31
slyedog's Avatar
slyedog
There is a difference between a Rushmore stage 1 and a pre Rushmore 103. The tq being higher after 2014 is the ho cams vs the pre 2014 stock cams. So a 2014 up will have more power. The op running more compression gives the extra tq along with the higher lift cam. The springs are at the cusp of .580-.600 the beehive can handle. I wouldn't have went that much cam without the headwork to support it. So the 120tq is more than just cams added. Had some headwork been done the HP would be higher.
Old Feb 14, 2016 | 03:06 PM
  #32
THE PEG's Avatar
THE PEG
Originally Posted by slyedog
The heavy valve springs are unneeded and may cause more wear and stress than by doing good. Also may hold back the build without headwork to support them. Overall not bad but you really only have what cams usually will deliver for power and add a couple ft lbs tq for the compression compared to stock. Not raining on parade but a 107 would have been likely cheaper and better performance. Just cams,good pipe and air cleaner on my 103 dyna was 93/107 sae. Either way enjoy the ride.
Same here. Just cams and I am at 92.12 hp and 106.67 tq on a15 Ultra Limited.
Old Feb 14, 2016 | 03:51 PM
  #33
--JP--'s Avatar
--JP--
Originally Posted by shore
120ft lbs with a cam swap, sign me up!!
seems real high, to be frank. Seeing as the HP #'s are inline, probably true #'s so who knows.
Have you ridden it yet?
No I won't get to ride it for probably 2 months. The highest temp I've seen today is 6*F
Old Feb 14, 2016 | 03:56 PM
  #34
IdahoHacker's Avatar
IdahoHacker
I've had more than one tech tell me that the 585 cam absolutely should not be used with stock springs. Lift is too high for stock springs.
Old Feb 14, 2016 | 04:56 PM
  #35
--JP--'s Avatar
--JP--
Yeah my dealer said "it looks like it would probably work with the stock springs but Harley suggests the other ones for a reason"
Old Feb 19, 2016 | 01:15 PM
  #36
MagnaFlow's Avatar
MagnaFlow
Former Sponsor
This bike sounds seriously fun to ride. Maybe some sound clips once its warm enough?
nadeauc
Engine Mechanical Topics
Jul 12, 2017 09:01 PM
GWD1983
15
Aug 31, 2014 09:27 AM
FIREHAWK116
May 18, 2010 06:56 AM
Cycleman6
Jan 13, 2008 06:41 PM
draycer
Exhaust System Topics
Sep 21, 2007 11:13 AM
